Schematic inventec inventec 15cr-u-si-1003 rev x01 schematic
BrandSAMSUNG
Motherboard ManufacturerINVENTEC
Project Code1310A2548301
Board Number1310A2548301
RevisionB
Date2012/5/02
CPU PlatformIVY BRIDGE
CPU SocketRPGA 989
PCH / SouthbridgeHM77
EC / KBCITE IT8527
Audio CodecIDT 92HD91
BIOS / SPI FlashSPI ROM 8MB
Charging ICBQ24728
Charger ArchitectureSYSTEM CHARGER
Power IC(s)TPS51461, TPS51123, TPS51650, TPS51219, TPS51216, RT8068, AP2132, CSD97374, GMT_AT718T
RAM TypeDDR3, DDR3L
RAM ArchitectureSO-DIMM
RAM Quantity / Slots2
LAN ICRTL 8151, RLT8161GSH-CG
WiFi / WLAN ICWLAN + BT MINI CARD
Card Reader ICREALTEK_RTS5239
USB Hub ICRTL 8151
HDMI Level ShifterHDMI
GPU TypeIVY BRIDGE
Graphics ArchitectureIVY BRIDGE
This Inventec-manufactured Samsung motherboard, project code 1310A2548301 revision B, is built around the Intel HM77 PCH and supports an IVY BRIDGE CPU in an RPGA 989 socket. The system utilizes an ITE IT8527 EC/KBC and an IDT 92HD91 audio codec. BIOS storage is provided by an 8MB SPI ROM. Power management is handled by a BQ24728 system charger and a suite of regulators including TPS51461, TPS51123, TPS51650, TPS51219, TPS51216, RT8068, AP2132, CSD97374, and GMT_AT718T. Memory configuration supports up to 8GB of DDR3 or DDR3L via two SO-DIMM slots. Networking is provided by RTL 8151 and RLT8161GSH-CG LAN ICs, with WLAN + BT Mini Card support. The board also features a REALTEK_RTS5239 card reader controller.
A: The motherboard uses an ITE IT8527 EC/KBC.
A: The BIOS is stored on an 8MB SPI ROM.
Q: What charging IC and architecture does this board use?
A: The system uses a BQ24728 system charger.
Q: What memory type and configuration is supported?
A: The board supports DDR3 and DDR3L memory in a SO-DIMM architecture with two slots, supporting up to 8GB total.
  • Inventec=Inventec 15CR-U-SI-1003 Rev X01.pdf
