hp compaq inventec 15cr dis gv2 1310a2548301 rev a02
This Inventec motherboard, model 1310A2548301 revision B, is designed for the MV-0118 project and dated 18-DEC-2012. The platform is built around an Intel Ivy Bridge CPU in an RPGA 989 socket paired with an HM77 PCH. Graphics are handled by an N14P-GV2 GPU. The system uses DDR3L SO-DIMM memory across two slots. The embedded controller is an ITE IT8527, and the audio codec is an IDT92HD91. The BIOS is stored on a 512KB SPI ROM. Power management includes a BQ24728 charger and multiple voltage regulators from Texas Instruments and Richtek. Networking is provided by a Realtek RTL8161GSH-CG LAN IC, and wireless connectivity is via a WLAN + BT Mini Card. A Realtek RTS5239 card reader is present, along with a NUVO NCT7717U thermal sensor and an ST HP3DC2 accelerometer.
A: The embedded controller is an ITE IT8527.
Q: What is the BIOS storage configuration?
A: The BIOS is stored on a 512KB SPI ROM.
A: The charging IC is a BQ24728.
Q: What is the memory configuration?
A: The board supports DDR3L SO-DIMM memory across two slots.
| Brand | Inventec |
| Model | 1310A2548301 |
| Motherboard Manufacturer | Inventec Corporation |
| Project Code | MV-0118 |
| Board Number | 1310A2548301 |
| Revision | B |
| Date | 18-DEC-2012 |
| CPU Platform | Ivy Bridge |
| CPU Socket | Socket RPGA 989 |
| PCH / Southbridge | HM77 |
| GPU Type | N14P-GV2 |
| Graphics Architecture | NV 14P-GV2 |
| EC / KBC | ITE IT8527 |
| Audio Codec | IDT92HD91 |
| BIOS / SPI Flash | 512KB SPI ROM |
| Charging IC | BQ24728 |
| Charger Architecture | BQ24728 |
| Power IC(s) | TPS51211, TPS51219, TPS51650, TPS51216, TPS51123, TPS51461, RT8068, AP2132 |
| RAM Architecture | DDR3L SO-DIMM |
| LAN IC | RTL8161GSH-CG |
| WiFi / WLAN IC | WLAN + BT Mini Card |
| Card Reader IC | Realtek RTS5239 |
| Thermal Sensor | NUVO_NCT7717U_SOT23 |
| Audio Amplifier | TI_TPA2012D2, TI_TPA3111D1, TI_TPA6130A2 |
| Accelerometer | ST_HP3DC2 |
MV-0118
1310A2548301
Ivy Bridge
989
HM77
N14P-GV2
NV 14P-GV2
IT8527
IDT92HD91
BQ24728
AP2132
RT8068
TPS51123
TPS51211
TPS51216
TPS51219
TPS51461
TPS51650
RTL8161GSH-CG
RTS5239
NUVO NCT7717U SOT23
TPA2012D2
TPA3111D1
TPA6130A2
ST HP3DC2
Motion / Position Sensor
MV-0118
1310A2548301
Ivy Bridge
989
HM77
N14P-GV2
NV 14P-GV2
IT8527
IDT92HD91
BQ24728
AP2132
RT8068
TPS51123
TPS51211
TPS51216
TPS51219
TPS51461
TPS51650
RTL8161GSH-CG
RTS5239
NUVO NCT7717U SOT23
TPA2012D2
TPA3111D1
TPA6130A2
ST HP3DC2
