Schematic hp compaq inventec 15cr dis gv2 1310a2548301 rev a02 schematic
BrandInventec
Model1310A2548301
Motherboard ManufacturerInventec Corporation
Project CodeMV-0118
Board Number1310A2548301
RevisionB
Date18-DEC-2012
CPU PlatformIvy Bridge
CPU SocketSocket RPGA 989
PCH / SouthbridgeHM77
GPU TypeN14P-GV2
Graphics ArchitectureNV 14P-GV2
EC / KBCITE IT8527
Audio CodecIDT92HD91
BIOS / SPI Flash512KB SPI ROM
Charging ICBQ24728
Charger ArchitectureBQ24728
Power IC(s)TPS51211, TPS51219, TPS51650, TPS51216, TPS51123, TPS51461, RT8068, AP2132
RAM TypeDDR3
RAM ArchitectureDDR3L SO-DIMM
RAM Quantity / Slots2
LAN ICRTL8161GSH-CG
WiFi / WLAN ICWLAN + BT Mini Card
Card Reader ICRealtek RTS5239
Thermal SensorNUVO_NCT7717U_SOT23
Audio AmplifierTI_TPA2012D2, TI_TPA3111D1, TI_TPA6130A2
AccelerometerST_HP3DC2
This Inventec motherboard, model 1310A2548301 revision B, is designed for the MV-0118 project and dated 18-DEC-2012. The platform is built around an Intel Ivy Bridge CPU in an RPGA 989 socket paired with an HM77 PCH. Graphics are handled by an N14P-GV2 GPU. The system uses DDR3L SO-DIMM memory across two slots. The embedded controller is an ITE IT8527, and the audio codec is an IDT92HD91. The BIOS is stored on a 512KB SPI ROM. Power management includes a BQ24728 charger and multiple voltage regulators from Texas Instruments and Richtek. Networking is provided by a Realtek RTL8161GSH-CG LAN IC, and wireless connectivity is via a WLAN + BT Mini Card. A Realtek RTS5239 card reader is present, along with a NUVO NCT7717U thermal sensor and an ST HP3DC2 accelerometer.
A: The embedded controller is an ITE IT8527.
Q: What is the BIOS storage configuration?
A: The BIOS is stored on a 512KB SPI ROM.
A: The charging IC is a BQ24728.
A: The board supports DDR3L SO-DIMM memory across two slots.
  • HP Compaq=Inventec 15CR DIS GV2 1310A2548301 Rev A02.pdf
