hp compaq presario cq40 compal la-4114p-amd_rev0.1 schematic
hp compaq presario cq40=1=compal la-4114p-amd_rev0.1.pdf
This Compal LA-4114P motherboard, revision 0.1 dated 2008-11-07, is built around a Mobile AMD S1G2 CPU platform with ATI RS780 (RX781) Northbridge and ATI SB700 Southbridge core logic. The discrete graphics subsystem features an ATI M82-SE GPU with dedicated VRAM. System memory consists of two DDR2 SO-DIMM slots supporting dual-channel architecture. The embedded controller is an ENE KB926, and the BIOS SPI flash is a 25LF080A. Audio is handled by an IDT 92HD71B7 codec, and networking is provided by a Realtek 8102EL 10/100M LAN controller. Thermal management uses an ADM1032ARMZ sensor, and the card reader is a JM385 5-in-1 controller. Wireless connectivity is supported via a Chicony CNF7047 WLAN module.
A: The BIOS SPI flash is a 25LF080A.
A: The embedded controller is an ENE KB926.
Q: What is the graphics configuration of this motherboard?
A: This motherboard uses a discrete ATI M82-SE GPU with dedicated VRAM.
A: The motherboard supports dual-channel DDR2 memory via two SO-DIMM slots.
| Model | LA-4114P |
| Board Number | LA-4114P |
| Revision | 0.1 |
| Date | 2008-11-07 |
| CPU Platform | Mobile AMD S1G2 CPU |
| PCH / Southbridge | ATI SB700 |
| GPU Type | ATI M82-SE |
| Graphics Architecture | Discrete ATI M82-SE |
| EC / KBC | ENE KB926 |
| Audio Codec | IDT 92HD71B7 |
| BIOS / SPI Flash | SPI ROM 25LF080A |
| BIOS Flash Exact Model | 25LF080A |
| Charging IC | Smart Battery |
| RAM Type | DDR2 |
| RAM Quantity / Slots | DDR2-SO-DIMM X2 |
| Thermal Sensor | ADM1032ARMZ |
| Card Reader IC | JM385 |
| LAN IC | Realtek 8102EL (10/100M) |
| WiFi / WLAN IC | Chicony CNF7047 |
| HDMI Level Shifter | HDMI |
LA-4114P
AMD S1G2
SB700
M82-SE
Discrete ATI M82-SE
KB926
92HD71B7
25LF080A
ADM1032ARMZ
JM385
8102EL
Chicony CNF7047
LA-4114P
AMD S1G2
SB700
M82-SE
Discrete ATI M82-SE
KB926
92HD71B7
25LF080A
ADM1032ARMZ
JM385
8102EL
Chicony CNF7047
