hp compaq presario r4000 compal_la-2421_rev0.6 schematic
hp compaq presario r4000=1=compal_la-2421_rev0.6.pdf
This Compal LA-2421 schematic, revision 0.6 dated January 5, 2005, documents an AMD K8 platform paired with an ATI RS480M GPU and ATI SB400 southbridge. The system utilizes an ENE KB910(L) embedded controller for keyboard and I/O buffer functions. Networking is handled by a Realtek RTL 8100CL LAN controller. The board features a TI PCI6411 CardBus controller, a TSB43AB22 IEEE 1394 controller, an ADM1032 thermal sensor, and an ICS 951412 clock generator. Memory is supported via DDR-SO-DIMM slots on a DDR memory bus. The platform includes PCI, LPC, USB 2.0, SATA, IDE, AC-LINK, and A-Link Express interfaces.
A: The embedded controller is an ENE KB910(L).
A: The LAN controller is a Realtek RTL 8100CL.
Q: What is the southbridge on this platform?
A: The southbridge is an ATI SB400.
Q: What thermal sensor is used on this motherboard?
A: The thermal sensor is an ADM1032.
| Document Number | LA-2421 |
| Revision | 0.6 |
| Date | Wednesday, January 05, 2005 |
| CPU Platform | AMD K8 |
| PCH / Southbridge | ATI SB400 |
| GPU Type | ATI RS480M |
| EC / KBC | ENE KB910(L) |
| LAN IC | RTL 8100CL |
| Thermal Sensor | ADM1032 |
| Clock Generator | ICS 951412 |
| CardBus Controller | TI PCI6411 |
| IEEE 1394 Controller | TSB43AB22 |
