hp compaq nc8000 inventec ruby_revd schematic
hp compaq nc8000=1=inventec ruby_revd.pdf
The Inventec RUBY1.0 motherboard, board number 131MBD2600-0-0D revision 03, is a Banias platform design dated 23-Jul-2003. It features an ICH4-M southbridge and an ATI_M10-P GPU supporting AGP4X/8X_BUS graphics. The system memory architecture is DDR SDRAM with a 200/333 Interface across two SODIMM slots. The embedded controller is a 47N227 KBC, and audio is handled by an AC97 Codec. Networking is provided by a BCM 5705 LAN IC and a Wireless LAN module. The board includes a System Charger for power management, SD Card support, and multiple USB ports (USB0, USB1, USB2, USB3, USB5). The document number is CSA3691.
Q: What is the board number and revision for this Inventec RUBY1.0 motherboard?
A: The board number is 131MBD2600-0-0D, revision 03.
Q: What CPU platform and southbridge does this motherboard use?
A: It uses the Banias CPU platform with an ICH4-M southbridge.
Q: What type of memory architecture is supported?
A: The board supports DDR SDRAM with a 200/333 Interface across two SODIMM slots.
Q: What is the embedded controller (EC/KBC) used on this board?
A: The EC/KBC is a 47N227.
| Brand | Inventec |
| Model | RUBY1.0 |
| Project Code | RUBY1.0 |
| Board Number | 131MBD2600-0-0D |
| Revision | 03 |
| Date | 23-Jul-2003 |
| CPU Platform | Banias |
| PCH / Southbridge | ICH4-M |
| GPU Type | ATI_M10-P |
| Graphics Architecture | AGP4X/8X_BUS |
| EC / KBC | 47N227 |
| Audio Codec | AC97 Codec |
| Charging IC | System Charger |
| RAM Type | DDR SDRAM |
| RAM Architecture | 200/333 Interface |
| LAN IC | BCM 5705 |
| WiFi / WLAN IC | Wireless LAN |
| Card Reader IC | SD Card |
| USB Hub IC | USB0, USB1, USB2, USB3, USB5 |
| HDMI Level Shifter | CRT |
| Document Number | CSA3691 |
