Schematic hp 6050a2548201 inventec 15cr-u-si-1030 15cr schematic
hp 6050a2548201 inventec 15cr-u-si-1030 15cr 1
BrandInventec
Motherboard ManufacturerInventec Corporation
Project Code1310xxxxx-0-0
Board Number1310A2548302 (MICRON)
RevisionB
Date21-OCT-2002
CPU PlatformPanther/Ivy Bridge
PCH / SouthbridgeHM77
EC / KBCITE IT8527
Audio CodecIDT92HD91
BIOS / SPI FlashSPI ROM
Charging ICBQ24728
Charger ArchitectureSystem Charger
Power IC(s)TPS51461, AP2132B, RT8068AZQW, TPS51123, TPS51650, TPS51219, TPS51216, CSD97374CQ4M
RAM TypeDDR3
RAM ArchitectureDDR3L SO-DIMM
RAM Quantity / Slots2
LAN ICRTL 8151
WiFi / WLAN ICWLAN + BT
Card Reader ICRealtek RTS5239
Thermal SensorNUVO_NCT7717U_SOT23
Alternate Board Number1310A2548701 (POWER BOARD 6L)
Alternate Board Number6050A2548701 (POWER BOARD 6L)
Alternate Board Number1310A2548601 (USB BOARD 8L)
Alternate Board Number6050A2548601 (USB BOARD 8L)
Alternate Board Number1310A2548801 (POWER BOARD 8L)
Alternate Board Number6050A2548801 (POWER BOARD 8L)
Alternate Board Number1310A2548501 (USB BOARD 6L)
Alternate Board Number6050A2548501 (USB BOARD 6L)
Alternate Board Number1310A2548301 (SAMSUNG)
This Inventec reference design, project code 1310xxxxx-0-0, is built around the Intel HM77 PCH and supports Panther/Ivy Bridge processors via an RPGA 989 socket. The platform utilizes DDR3 memory with two DDR3L SO-DIMM slots. System management is handled by an ITE IT8527 EC/KBC, while audio is provided by an IDT92HD91 codec. The charging architecture is a system charger configuration using a BQ24728 IC, supported by a comprehensive power delivery network including TPS51461, AP2132B, RT8068AZQW, TPS51123, TPS51650, TPS51219, TPS51216, and CSD97374CQ4M regulators. Wired connectivity is via an RTL 8151 LAN IC, and wireless connectivity is provided by a WLAN + BT mini card. A Realtek RTS5239 card reader and NUVO_NCT7717U thermal sensor are also integrated. The main board number is 1310A2548302 (MICRON), with an alternate SAMSUNG variant 1310A2548301, and multiple sub-board numbers for power and USB boards.
A: The EC/KBC is an ITE
  • HP=1=6050A2548201_Inventec_15CR-U-SI-1030_15CR.pdf
