Schematic hp envy 15-j 15cr uma mv 6050a2548201-a02-0221 schematic
BrandInventec
Model1310A2548201
Motherboard ManufacturerInventec
Project Code58
Board Number1310A2548201
RevisionB
Date21-FEB-2013
CPU PlatformIVY BRIDGE
PCH / SouthbridgeEC / KBCITE IT8527
EC/KBC PackageSOCKET RPGA 989
Audio CodecIDT92HD91
BIOS / SPI FlashSPI ROM
BIOS Flash Capacity8MB
Charging ICBQ24728
Charger ArchitectureSYSTEM CHARGER
Power IC(s)TPS51461, TPS51123, TPS51650, TPS51219, TPS51216, RT8068AZQW, CSD97374CQ4M
RAM TypeDDR3, DDR3L
RAM ArchitectureSO-DIMM
RAM Quantity / Slots2
Card Reader ICREALTEK_RTS5239
LAN ICRLT8161GSH-CG
WiFi / WLAN ICWLAN + BT
HDMI Level ShifterHDMI
GPU TypeUMA
Graphics ArchitectureIVY BRIDGE
[/TD]
[TR]
This Inventec motherboard, model 1310A2548201 revision B, is designed for the Intel IVY BRIDGE CPU platform with integrated UMA graphics. The board utilizes an ITE IT8527 EC/KBC in a Socket RPGA 989 package. System memory consists of two DDR3/DDR3L SO-DIMM slots. The BIOS is stored on an 8MB SPI ROM. Power management is handled by a BQ24728 system charger and a multi-rail VR solution including TPS51461, TPS51123, TPS51650, TPS51219, TPS51216, RT8068AZQW, and CSD97374CQ4M. The audio subsystem is built around an IDT92HD91 codec. Networking is provided by a Realtek RLT8161GSH-CG Gigabit LAN controller. A Realtek RTS5239 card reader is integrated for SD card support.
A: The motherboard uses an ITE IT8527 EC/KBC in a Socket RPGA 989 package.
Q: What is the BIOS flash capacity and type?
A: The BIOS is stored on an 8MB SPI ROM.
Q: What charging IC is used?
A: The system charger IC is a BQ24728.
Q: What is the memory configuration?
A: The board supports up to 8GB of DDR3/DDR3L memory via two SO-DIMM slots.
  • HP_Envy_15-J_=15CR_UMA_MV_6050A2548201-A02-0221_DR-BIOS.COM.zip
