inventec inventec 15cr uma 0118 rev a02
This Inventec 15CR-UMA-MV-0118 motherboard, board number 1310A2548201 revision A02, is built around the Intel Ivy Bridge platform with an RPGA 989 socket and HM77 PCH. The system is managed by an ITE IT8527 EC/KBC and boots from an 8MB SPI ROM. Memory is provided via two DDR3L SO-DIMM slots supporting up to 8GB. Power management is handled by a BQ24728 charger IC alongside a multi-rail VR solution including TPS51461, TPS51123, TPS51650, TPS51219, RT8068, AP2132B, and CSD97374CQ4M. Integrated audio is driven by an IDT92HD91 codec with TI TPA3111D1 and TPA2012D2 amplifiers. Connectivity includes a Realtek RLT8161GSH-CG Gigabit LAN controller, a Realtek RTS5239 card reader, and a WLAN + BT Mini Card. An Nuvoton NCT7717U thermal sensor provides temperature monitoring.
A: The motherboard uses an ITE IT8527 EC/KBC.
A: The system uses an 8MB SPI ROM for BIOS storage.
Q: What charging IC is used?
A: The charging circuit is built around a BQ24728 IC.
A: The board supports DDR3L SO-DIMM memory with two slots, supporting up to 8GB total.
| Brand | Inventec |
| Model | 15CR-UMA-MV-0118 |
| Motherboard Manufacturer | Inventec Corporation |
| Project Code | MV-0118 |
| Board Number | 1310A2548201 |
| Revision | A02 |
| Date | 18-DEC-2012 |
| CPU Platform | Ivy Bridge |
| CPU Socket | Socket RPGA 989 |
| PCH / Southbridge | HM77 |
| EC / KBC | ITE IT8527 |
| Audio Codec | IDT92HD91 |
| BIOS / SPI Flash | 8MB SPI ROM |
| Charging IC | BQ24728 |
| Power IC(s) | TPS51461, TPS51123, TPS51650, TPS51219, RT8068, AP2132B, CSD97374CQ4M |
| RAM Type | DDR3L SO-DIMM |
| RAM Architecture | DDR3 |
| Card Reader IC | Realtek RTS5239 |
| LAN IC | Realtek RLT8161GSH-CG |
| WiFi / WLAN IC | WLAN + BT Mini Card |
| HDMI Level Shifter | RTJR |
| Thermal Sensor | Nuvoton NCT7717U SOT23 |
| Audio Amplifier | TI TPA3111D1, TI TPA2012D2 |
| USB Hub IC | TI TPA6130A2 |
MV-0118
1310A2548201
Ivy Bridge
989
HM77
IT8527
IDT92HD91
BQ24728
AP2132B
CSD97374CQ4M
RT8068
TPS51123
TPS51219
TPS51461
TPS51650
DDR3L
RTS5239
RLT8161GSH-CG
NCT7717U SOT23
TPA2012D2
TPA3111D1
TPA6130A2
MV-0118
1310A2548201
Ivy Bridge
989
HM77
IT8527
IDT92HD91
BQ24728
AP2132B
CSD97374CQ4M
RT8068
TPS51123
TPS51219
TPS51461
TPS51650
DDR3L
RTS5239
RLT8161GSH-CG
NCT7717U SOT23
TPA2012D2
TPA3111D1
TPA6130A2
