Schematic hp dv6-7000 goya balen 11254-3 schematic
BrandWistron Corporation
Project Code91.4ST01.001
Board Number11254
Revision-1
DateWednesday, January 04, 2012
Document NumberA41103
CPU PlatformIVY Bridge (rPGA989)
PCH / SouthbridgeIntel PCH (Panther Point)
GPU TypeNvidia N13P GL
Graphics ArchitectureG709/P2800
dGPU Chip NumberN13P GL
dGPU to UMA Conversion SupportDIS_OPT Schematic: No stuff
Audio CodecIDT92HD91
BIOS / SPI FlashSPI Flash 8MB
Charging ICBQ24738
Power IC(s)TPS51461, NCP3218G, VT1323, RT8207MZ, RT8223M, SN1003055RUWR, RT8068A
RAM TypeDDRIII 1600/1333
RAM ArchitectureChannel A Slot 0, Slot 1; Channel B
LAN ICRealtek RTL8111G
WiFi / WLAN IC802.11a/b/g/n Bluetooth combo Mini-Card
Card Reader ICRealtek RTS5229
HDMI Level ShifterHDMI 1.4
This Wistron Colossus 1 motherboard, project code 91.4ST01.001 and board number 11254 revision -1, is built around an Intel IVY Bridge CPU in rPGA989 socket with an Intel Panther Point PCH. The discrete graphics solution uses an Nvidia N13P GL GPU (G709/P2800) with 64MBx16 VRAM/DDR3, and the schematic explicitly marks DIS_OPT as "No stuff" for the Optimus configuration, indicating dGPU-only operation. The system BIOS resides on an 8MB SPI flash. Power management is handled by a BQ24738 charger and multiple DC/DC converters including TPS51461, NCP3218G, VT1323, RT8207MZ, RT8223M, SN1003055RUWR, and RT8068A. Audio is provided by an IDT92HD91 codec, networking by a Realtek RTL8111G Gigabit NIC, and card reading by a Realtek RTS5229 controller. Memory configuration supports DDRIII 1600/1333 across two channels.
A: The motherboard uses an 8MB SPI flash for the BIOS.
Q: Does this motherboard support dGPU to UMA conversion?
A: No. The schematic explicitly marks DIS_OPT (Discrete Optimus) as "No stuff", meaning the discrete GPU is permanently installed and no UMA conversion is supported.
A: The charging IC is a BQ24738.
Q: What is the discrete GPU model on this motherboard?
A: The discrete GPU is an Nvidia N13P GL (G709/P2800) with 64MBx16 VRAM/DDR3.
  • HP_DV6-7000_Goya_Balen_11254-3_DR_BIOS.COM.zip
