hp dv6 quanta ut3 ut5_dis schematic
hp dv6=1=quanta ut3 ut5_dis.pdf
This Quanta UT3/5NB5 motherboard, dated October 20, 2008, is built around the Intel Penryn 478P CPU platform with a Cantiga Northbridge and ICH9-M Southbridge. Graphics are handled by a discrete nVIDIA NB9M-GE or NB9P-GS GPU supporting 64-bit or 128-bit memory interfaces. The system uses two DDRII-SODIMM slots supporting DDRII 667/800 MHz memory. Power management is handled by an ISL6251AHAZ-T charger and multiple regulators including ISL6237IRZ-T, ISL6262A, RT8204, TPS51116REGR, and Oz8119. The embedded controller is an ENE KBC paired with a KB3926 C0 flash ROM. Audio is provided by an IDT92HD75B3 codec with TPA6047 and TPA3007D1 amplifiers. Networking includes an RTL8102E/8111C LAN controller and a Wireless LAN/TV module. Additional features include a JMICRO 380 card reader, LIS3LV02D accelerometer, G9931 thermal sensor, and an ICS 9LPRS355B MLF64PIN clock generator.
Q: What EC/KBC and flash ROM are used on this motherboard?
A: The embedded controller is an ENE KBC with a KB3926 C0 flash ROM.
A: The system charger is an ISL6251AHAZ-T.
Q: What audio codec and amplifiers are used on this motherboard?
A: The audio codec is an IDT92HD75B3, with TPA6047 and TPA3007D1 amplifiers.
A: The LAN controller is an RTL8102E/8111C.
Q: What clock generator is used on this motherboard?
A: The clock generator is an ICS 9LPRS355B MLF64PIN.
| Project Code | UT3/5NB5 |
| Date | Monday, October 20, 2008 |
| Northbridge | Cantiga |
| Southbridge | ICH9-M |
| GPU Type | nVIDIA NB9M-GE / NB9P-GS |
| Graphics Architecture | 64 Bit / 128 Bit |
| EC / KBC | ENE KBC |
| Audio Codec | IDT92HD75B3 |
| LAN IC | RTL8102E/8111C |
| Charging IC | ISL6251AHAZ-T |
| Power IC(s) | ISL6237IRZ-T / ISL6262A / RT8204 / TPS51116REGR / Oz8119 |
| RAM Type | DDRII 667/800 MHz |
| RAM Architecture | DDRII-SODIMM x2 |
| Audio Amplifier | TPA6047 / TPA3007D1 |
| Card Reader IC | JMICRO 380 |
| Accelerometer | LIS3LV02D |
| Thermal Sensor | G9931 |
| Clock Generator | ICS 9LPRS355B MLF64PIN |
| EC Flash / ROM | KB3926 C0 |
| WiFi / WLAN IC | Wireless LAN/TV |
| HDMI Level Shifter | Level Shift |
5NB5
UT3
Penryn
ICH9
NB9M-GE
NB9P-GS
64 Bit / 128 Bit
IDT92HD75B3
RTL8102E/8111C
ISL6251AHAZ-T
ISL6237IRZ-T
ISL6262A
OZ8119
RT8204
TPS51116REGR
TPA3007D1
TPA6047
JMICRO 380
LIS3LV02D
Motion / Position Sensor
G9931
KB3926 C0
5NB5
UT3
Penryn
ICH9
NB9M-GE
NB9P-GS
64 Bit / 128 Bit
IDT92HD75B3
RTL8102E/8111C
ISL6251AHAZ-T
ISL6237IRZ-T
ISL6262A
OZ8119
RT8204
TPS51116REGR
TPA3007D1
TPA6047
JMICRO 380
LIS3LV02D
G9931
KB3926 C0
