hp_dv6 quanta_qt6_rev-2a schematic
hp_dv6=1=quanta_qt6_rev-2a.pdf
The Quanta QT6NB5 project is a notebook motherboard platform dated February 27, 2008, revision 2A. It is built around an Intel Penryn 478P (uPGA) CPU with a 35W TDP, paired with the Cantiga northbridge and ICH-9M southbridge. System memory consists of two DDRII-SODIMM slots supporting DDRII 667/800 MHz modules. The embedded controller is a KB3926 C0. Power management is handled by an ISL6237IRZ-T system power IC, an ISL6266A CPU core regulator, a TPS51116REGR DDR_VTERM regulator, and an RT8204 for VCCP and GMCH voltages. The charging IC is an ISL6251AHAZ-T. Audio is provided by an IDT92HD71B7X codec with a TPA6017A2 amplifier. Networking uses a Realtek RTL8102E 10/100 LAN controller. A Realtek RTS5158E card reader and an ST LIS3LV02DL accelerometer are also present on this platform.
A: The embedded controller is a KB3926 C0.
A: The system charger IC is an ISL6251AHAZ-T.
Q: What audio codec and amplifier are used on this motherboard?
A: The audio codec is an IDT92HD71B7X, and the audio amplifier is a TPA6017A2.
Q: What memory type and configuration does this motherboard support?
A: It supports DDRII memory via two DDRII-SODIMM slots at 667/800 MHz.
| Project Code | QT6NB5 |
| Revision | 2A |
| Date | Wednesday, February 27, 2008 |
| PCH / Southbridge | ICH-9M |
| EC / KBC | KB3926 C0 |
| Audio Codec | IDT92HD71B7X |
| Charging IC | ISL6251AHAZ-T |
| Power IC(s) | ISL6237IRZ-T, ISL6266A, TPS51116REGR, RT8204 |
| RAM Type | DDR II |
| RAM Architecture | DDRII-SODIMM |
| LAN IC | RTL8102E |
| Card Reader IC | RTS5158E |
| Audio Amplifier | TPA6017A2 |
| Thermal Sensor | LIS3LV02DL |
QT6NB5
Penryn
ICH-9M
KB3926 C0
IDT92HD71B7X
ISL6251AHAZ-T
ISL6237IRZ-T
ISL6266A
RT8204
TPS51116REGR
RTL8102E
RTS5158E
TPA6017A2
LIS3LV02DL
QT6NB5
Penryn
ICH-9M
KB3926 C0
IDT92HD71B7X
ISL6251AHAZ-T
ISL6237IRZ-T
ISL6266A
RT8204
TPS51116REGR
RTL8102E
RTS5158E
TPA6017A2
LIS3LV02DL
