hp dv6-7000 goya balen 11254-3
This Wistron Colossus 1 motherboard, project code 91.4ST01.001 and board number 11254 revision -1, is built around an Intel IVY Bridge CPU in rPGA989 socket with an Intel Panther Point PCH. The discrete graphics solution uses an Nvidia N13P GL GPU (G709/P2800) with 64MBx16 VRAM/DDR3, and the schematic explicitly marks DIS_OPT as "No stuff" for the Optimus configuration, indicating dGPU-only operation. The system BIOS resides on an 8MB SPI flash. Power management is handled by a BQ24738 charger and multiple DC/DC converters including TPS51461, NCP3218G, VT1323, RT8207MZ, RT8223M, SN1003055RUWR, and RT8068A. Audio is provided by an IDT92HD91 codec, networking by a Realtek RTL8111G Gigabit NIC, and card reading by a Realtek RTS5229 controller. Memory configuration supports DDRIII 1600/1333 across two channels.
A: The motherboard uses an 8MB SPI flash for the BIOS.
A: No. The schematic explicitly marks DIS_OPT (Discrete Optimus) as "No stuff", meaning the discrete GPU is permanently installed and no UMA conversion is supported.
A: The charging IC is a BQ24738.
Q: What is the discrete GPU model on this motherboard?
A: The discrete GPU is an Nvidia N13P GL (G709/P2800) with 64MBx16 VRAM/DDR3.
| Project Code | 91.4ST01.001 |
| Board Number | 11254 |
| Revision | -1 |
| Date | Wednesday, January 04, 2012 |
| Document Number | A41103 |
| CPU Platform | IVY Bridge (rPGA989) |
| PCH / Southbridge | Intel PCH (Panther Point) |
| GPU Type | Nvidia N13P GL |
| Graphics Architecture | G709/P2800 |
| dGPU Chip Number | N13P GL |
| dGPU to UMA Conversion Support | DIS_OPT Schematic: No stuff |
| Audio Codec | IDT92HD91 |
| BIOS / SPI Flash | SPI Flash 8MB |
| Charging IC | BQ24738 |
| Power IC(s) | TPS51461, NCP3218G, VT1323, RT8207MZ, RT8223M, SN1003055RUWR, RT8068A |
| RAM Type | DDRIII 1600/1333 |
| RAM Architecture | Channel A Slot 0, Slot 1; Channel B |
| LAN IC | Realtek RTL8111G |
| WiFi / WLAN IC | 802.11a/b/g/n Bluetooth combo Mini-Card |
| Card Reader IC | Realtek RTS5229 |
| HDMI Level Shifter | HDMI 1.4 |
91.4ST01.001
11254
Ivy Bridge
N13P-GL
G709/P2800
N13P-GL
IDT92HD91
BQ24738
NCP3218G
RT8068A
RT8207MZ
RT8223M
SN1003055RUWR
TPS51461
VT1323
RTL8111G
RTS5229
91.4ST01.001
11254
Ivy Bridge
N13P-GL
G709/P2800
N13P-GL
IDT92HD91
BQ24738
NCP3218G
RT8068A
RT8207MZ
RT8223M
SN1003055RUWR
TPS51461
VT1323
RTL8111G
RTS5229
