dell latitude e6410 compal la-5772p nal21 r.02 x01
This Dell NAL21 motherboard, manufactured by Compal Electronics, is based on the M10 Margaux SW GFX project with board number LA-5772P (DAA00001F00) revision 0.2(X01). The platform utilizes an rPGA Auburndale CPU with an FCBGA IBEXPEAK-M PCH and features an N10M-NS-S GPU for switchable graphics. The system is managed by an SMSC KBC MEC5045 EC/KBC controller. BIOS storage is provided by W25X64VSSIG (32M) and W25Q64VSSIG (64M) SPI flash ICs. Memory configuration consists of two DDR3 DIMM slots supporting 800MHz/1066MHz. The charging architecture is handled by an ECE1077 charger IC. Networking is supported by an Intel Hanksville 82577LM LAN controller and a BCM5882 WLAN IC. The audio codec is a TLV320AIC3004. Display connectivity includes multiple HDMI level shifters such as the PI3VDP8200, PI3VEDP212, PI3VDP612-A, PI3V712-A, and PI3C3125.
Q: What BIOS IC models are used on this motherboard?
A: This motherboard uses W25X64VSSIG (32M 4K sector) and W25Q64VSSIG (64M 4K sector) SPI flash ICs.
A: The EC/KBC controller is an SMSC KBC MEC5045.
Q: What is the charging IC and architecture on this motherboard?
A: The charging IC is an ECE1077, and the architecture is labeled as CHARGER.
Q: What is the memory configuration on this motherboard?
A: The motherboard supports two DDR3 DIMM slots operating at 800MHz/1066MHz.
Q: What graphics configuration does this motherboard support?
A: This motherboard supports switchable graphics (SW GFX) with an N10M-NS-S GPU.
| Model | NAL21 |
| Project Code | M10 Margaux SW GFX |
| Board Number | LA-5772P ( DAA00001F00) |
| Revision | 0.2(X01) |
| Date | Monday, June 08, 2009 |
| Document Number | 401766B |
| CPU Platform | rPGA Auburndale + FCBGA PCH IBEXPEAK-M |
| GPU Type | N10M-NS-S |
| Graphics Architecture | SW GFX |
| EC / KBC | SMSC KBC MEC5045 |
| Audio Codec | TLV320AIC3004 |
| BIOS / SPI Flash | W25X64VSSIG (32M 4K sector), W25Q64VSSIG (64M 4K sector) |
| Charging IC | ECE1077 |
| Charger Architecture | CHARGER |
| RAM Type | DDRIII-DIMM X2 |
| RAM Architecture | DDR3 800MHz/1066MHz |
| LAN IC | Intel Hanksville 82577LM |
| WiFi / WLAN IC | BCM5882 |
| Card Reader IC | R5U242 |
| USB Hub IC | SLG8SP585 |
| HDMI Level Shifter | PI3VDP8200, PI3VEDP212, PI3VDP612-A, PI3V712-A, PI3C3125 |
M10
Ibex Peak-M
N10M-NS-S
SW GFX
MEC5045
TLV320AIC3004
W25Q64VSSIG
W25X64VSSIG
ECE1077
HANKSVILLE 82577LM
BCM5882
R5U242
SLG8SP585
PI3C3125
PI3V712-A
PI3VDP612-A
PI3VDP8200
PI3VEDP212
M10
Ibex Peak-M
N10M-NS-S
SW GFX
MEC5045
TLV320AIC3004
W25Q64VSSIG
W25X64VSSIG
ECE1077
HANKSVILLE 82577LM
BCM5882
R5U242
SLG8SP585
PI3C3125
PI3V712-A
PI3VDP612-A
PI3VDP8200
PI3VEDP212
