Schematic dell latitude e6410 la5472p gerber rev 1.0 schematic
BrandDell
ModelNCL01E2 Rothschild DSC
Project CodeNCL01
Board NumberLA-5472P
Revision1.0(A00)
Date2010-01-20
CPU PlatformrPGA Arrandale + FCBGA PCH IBEXPEAK-M
PCH / SouthbridgeIBEXPEAK-M
GPU TypeN10M-NS-S
EC / KBCSMSC MEC5045
Audio Codec92HD81B1
BIOS / SPI FlashW25X32BVSSIG, W25Q64BVSSIG
BIOS Flash Exact ModelW25X32BVSSIG, W25Q64BVSSIG
BIOS Flash Capacity32M, 64M
BIOS Flash PackageSOIC-8
Charging ICCHARGER
RAM TypeDDRIII
RAM ArchitectureDIMM X2
LAN ICIntel 82577LM
WiFi / WLAN ICSMSC SIO
Card Reader ICR5U242
USB Hub ICPI3L720ZHE
HDMI Level ShifterPI3VDP8200ZBEX
Thermal SensorEMC4002
Power IC(s)SLG8SP585
This Dell NCL01E2 Rothschild DSC motherboard, manufactured by Compal Electronics as board number LA-5472P revision 1.0(A00), is built around the Intel rPGA Arrandale CPU platform with an IBEXPEAK-M PCH. Graphics are handled by an N10M-NS-S GPU. The system firmware is stored on two SPI flash ICs: a W25X32BVSSIG (32Mbit) and a W25Q64BVSSIG (64Mbit), both in SOIC-8 packages. Embedded controller functions are managed by an SMSC MEC5045. Audio is provided by a 92HD81B1 Azalia codec, while networking is handled by an Intel 82577LM LAN controller. The board supports two DDRIII DIMM slots for memory expansion.
A: This motherboard uses a W25X32BVSSIG (32Mbit) and a W25Q64BVSSIG (64Mbit) SPI flash IC, both in SOIC-8 packages.
A: The embedded controller is an SMSC MEC5045.
A: The schematic identifies the charging IC as CHARGER.
A: This motherboard supports DDRIII memory via two DIMM slots.
  • Dell_Latitude_E6410=LA5472P_GERBER_Rev_1.0_DR-BIOS.COM.zip
