dell latitude e6410 la5472p gerber rev 1.0
This Dell NCL01E2 Rothschild DSC motherboard, manufactured by Compal Electronics as board number LA-5472P revision 1.0(A00), is built around the Intel rPGA Arrandale CPU platform with an IBEXPEAK-M PCH. Graphics are handled by an N10M-NS-S GPU. The system firmware is stored on two SPI flash ICs: a W25X32BVSSIG (32Mbit) and a W25Q64BVSSIG (64Mbit), both in SOIC-8 packages. Embedded controller functions are managed by an SMSC MEC5045. Audio is provided by a 92HD81B1 Azalia codec, while networking is handled by an Intel 82577LM LAN controller. The board supports two DDRIII DIMM slots for memory expansion.
Q: What BIOS IC models are used on this motherboard?
A: This motherboard uses a W25X32BVSSIG (32Mbit) and a W25Q64BVSSIG (64Mbit) SPI flash IC, both in SOIC-8 packages.
A: The embedded controller is an SMSC MEC5045.
A: The schematic identifies the charging IC as CHARGER.
A: This motherboard supports DDRIII memory via two DIMM slots.
| Model | NCL01E2 Rothschild DSC |
| Project Code | NCL01 |
| Board Number | LA-5472P |
| Revision | 1.0(A00) |
| Date | 2010-01-20 |
| CPU Platform | rPGA Arrandale + FCBGA PCH IBEXPEAK-M |
| PCH / Southbridge | IBEXPEAK-M |
| GPU Type | N10M-NS-S |
| EC / KBC | SMSC MEC5045 |
| Audio Codec | 92HD81B1 |
| BIOS / SPI Flash | W25X32BVSSIG, W25Q64BVSSIG |
| BIOS Flash Exact Model | W25X32BVSSIG, W25Q64BVSSIG |
| BIOS Flash Capacity | 32M, 64M |
| BIOS Flash Package | SOIC-8 |
| Charging IC | CHARGER |
| RAM Architecture | DIMM X2 |
| LAN IC | Intel 82577LM |
| WiFi / WLAN IC | SMSC SIO |
| Card Reader IC | R5U242 |
| USB Hub IC | PI3L720ZHE |
| HDMI Level Shifter | PI3VDP8200ZBEX |
| Thermal Sensor | EMC4002 |
| Power IC(s) | SLG8SP585 |
NCL01
LA-5472P
Arrandale
N10M-NS-S
MEC5045
92HD81B1
W25Q64BVSSIG
W25X32BVSSIG
82577LM
R5U242
PI3L720ZHE
PI3VDP8200ZBEX
EMC4002
SLG8SP585
NCL01
LA-5472P
Arrandale
N10M-NS-S
MEC5045
92HD81B1
W25Q64BVSSIG
W25X32BVSSIG
82577LM
R5U242
PI3L720ZHE
PI3VDP8200ZBEX
EMC4002
SLG8SP585
