Schematic dell latitude e6410 compal la-5472p rev1.0 schematic
dell latitude e6410 compal_la-5472p_rev1.0 schematic
dell latitude e6410=1=compal_la-5472p_rev1.0.pdf
BrandDELL
Document NumberLA-5472P
Revision1.0 (A00)
DateWednesday, January 20, 2010
ModelNCL01 LA-5472P LS-5471P/5473P/5574P MB PCB
CPU Platform1060 pin / Socket G1
GPU TypeN10M-S
PCH / SouthbridgeIntel Ibex Peak
Audio CodecALC269
LAN ICRTL8111E
Card Reader ICRTS5209
EC / KBCKB9012QF A3
Charging ICBQ24745
Power IC(s)TPS51120, TPS51125, TPS51220, TPS51275, TPS5130, TPS51427, TPS51620, TPS51916, TPS54317, TPS54320, TPS54418, TPS54620, TPS54622, TPS54821, TPS54917, TPS54922, TPS54980, TPS54C20, TPS54J20, TPS54x20, TPS54x22, TPS54x80, TPS54xC20, TPS54xJ20, TPS54x20, TPS54x22, TPS54x80, TPS54xC20, TPS54xJ20
RAM TypeDDR3
RAM Architecture800MHz / 1066MHz
RAM Quantity / Slots2
WiFi / WLAN ICAzureWave AW-NB037
USB Hub ICGL850G
HDMI Level ShifterPTN3350BS
Thermal SensorNCT1008
BIOS / SPI FlashW25Q32BV
This Dell Compal LA-5472P (Rev 1.0 A00) motherboard, dated January 20, 2010, is built around a Socket G1 (1060 pin) CPU platform with an Intel Ibex Peak PCH. Graphics are handled by an N10M-S GPU. The system memory architecture supports DDR3 at 800MHz or 1066MHz across two slots. The embedded controller is a KB9012QF A3, and the BIOS SPI flash is a W25Q32BV. Audio is managed by an ALC269 codec, while networking is provided by an RTL8111E LAN IC. The charging circuit uses a BQ24745 controller. Additional notable components include an AzureWave AW-NB037 WLAN module, a GL850G USB hub controller, a PTN3350BS HDMI level shifter, an RTS5209 card reader, and an NCT1008 thermal sensor.
Q: What is the document number and revision of this motherboard?
A: The document number is LA-5472P, revision 1.0 (A00).
Q: What BIOS SPI flash IC is used on this motherboard?
A: The BIOS SPI flash IC is a W25Q32BV.
A: The EC/KBC is a KB9012QF A3.
Q: What is the CPU socket and platform?
A: The CPU platform uses a 1060 pin Socket G1.
  • Dell Latitude E6410=1=compal_la-5472p_Rev1.0.zip
