Schematic dell e6410 la5471p gerber rev 1.0 schematic
BrandDell
ModelNCL00 NCL10(ATG)
Motherboard ManufacturerCompal Electronics, Inc.
Project CodeE2 Rothschild UMA
Board NumberLA-5471P
Revision1.0 (A00)
DateWednesday, January 20, 2010
CPU PlatformrPGA Arrandale + FCBGA PCH IBEXPEAK-M
EC / KBCSMSC MEC5045
Audio CodecTI TLV320AIC3004
BIOS / SPI FlashW25Q32VSSIG / W25Q64BVSSIG
BIOS Flash Exact ModelW25Q32VSSIG / W25Q64BVSSIG
BIOS Flash Capacity32M / 64M
Charging ICSLG8SP585
LAN ICIntel 82577LM
WiFi / WLAN ICBCM5882
Card Reader ICR5U242
Thermal SensorGUARDIAN III EMC4002
RAM TypeDDRIII
RAM ArchitectureDIMM X2
RAM Quantity / Slots2
GPU TypeUMA
Graphics ArchitectureUMA
HDMI Level ShifterPI3VDP8200ZBEX
USB Hub ICPI3L720ZHE
Power IC(s)ECE5028 / ECE1077
This Dell NCL00/NCL10(ATG) motherboard, manufactured by Compal Electronics under board number LA-5471P revision 1.0 (A00), is built on the E2 Rothschild UMA platform. The CPU platform is rPGA Arrandale with an FCBGA PCH IBEXPEAK-M. The system utilizes DDRIII memory across two DIMM slots. Graphics are integrated UMA. The BIOS SPI flash is provided by either a W25Q32VSSIG (32M) or W25Q64BVSSIG (64M) IC. The embedded controller is an SMSC MEC5045. Audio is handled by a TI TLV320AIC3004 codec. Networking includes an Intel 82577LM LAN controller and a BCM5882 wireless module. The charging IC is an SLG8SP585, with power management supported by ECE5028 and ECE1077 ICs. A GUARDIAN III EMC4002 thermal sensor is present. The HDMI level shifter is a PI3VDP8200ZBEX, and the USB hub IC is a PI3L720ZHE. The card reader controller is an R5U242.
Q: What BIOS IC models are used on this motherboard?
A: The BIOS SPI flash is provided by either a W25Q32VSSIG (32M) or W25Q64BVSSIG (64M) IC.
A: The embedded controller is an SMSC MEC5045.
Q: What is the charging architecture on this motherboard?
A: The charging IC is an SLG8SP585.
A: The system uses DDRIII memory across two DIMM slots.
  • Dell_E6410=LA5471P_GERBER_Rev_1.0_DR-BIOS.COM.zip
