toshiba satellite l650 l650d bl10adg 6050a2333101-mb-a01 2009.12.28
This Inventec Berlin 10AD (CSA3) motherboard, revision X01, is built around the AMD Danube (Champlain) CPU platform paired with an AMD RS880M/MC GPU and SB820M southbridge. The system supports two DDR3 SODIMM slots for memory expansion. The embedded controller is a Winbond W781LH, and the audio codec is a CX20671. Wired connectivity is provided by dual Atheros AR8151 and AR8152 LAN controllers, while wireless is handled by an Atheros module. The charging circuit is managed by a MAX17435ETG+ controller. The BIOS is stored on an SPI EEROM. The board also features an SN75LVCP412 for both card reader and HDMI level shifting duties.
Q: What is the board number and revision for this motherboard?
A: The board number is 631310A2333201, revision X01.
A: The EC/KBC is a Winbond W781LH.
A: The charging IC is a MAX17435ETG+ in a TQFN-24 package.
A: This motherboard supports DDR3 memory across two SODIMM slots.
| Brand | INVENTEC |
| Model | Berlin 10AD |
| Project Code | CSA3 |
| Board Number | 631310A2333201 |
| Revision | X01 |
| Date | 28-Dec-2009 |
| CPU Platform | AMD Danube (Champlain) |
| EC / KBC | WINBOND W781LH |
| Audio Codec | CX20671 |
| BIOS / SPI Flash | SPI EEROM |
| Charging IC | MAX_MAX17435ETG+_TQFN_24 |
| LAN IC | ATHEROS AR8151 |
| LAN IC | ATHEROS AR8152 |
| RAM Type | DDR3 |
| RAM Architecture | SODIMM0, SODIMM1 |
| Card Reader IC | SN75LVCP412 |
| WiFi / WLAN IC | Atheros |
| HDMI Level Shifter | SN75LVCP412 |
| GPU Type | AMD RS880M/MC |
| Graphics Architecture | SB820M |
CSA3
631310A2333201
Danube Champlain
W781LH
CX20671
MAX_MAX17435ETG
_TQFN_24
AR8151
AR8152
SN75LVCP412
SN75LVCP412
MC
RS880M
SB820M
CSA3
631310A2333201
Danube Champlain
W781LH
CX20671
MAX_MAX17435ETG
_TQFN_24
AR8151
AR8152
SN75LVCP412
SN75LVCP412
MC
RS880M
SB820M
