Schematic toshiba satellite l650 l650d bl10adg 6050a2333101-mb schematic
BrandInventec
ModelBerlin 10AD
Motherboard ManufacturerInventec
Project CodeBerlin 10AD
Board NumberCSA3631
RevisionX01
Date2-Dec-2009
CPU PlatformAMD Danube (Champlain)
GPU TypeAMD RS880M/MC
Graphics ArchitectureAMD Madison LP
EC / KBCWINBOND
Audio CodecCX20671
Charging ICMAX_MAX17435ETG+_TQFN_24P
Charger ArchitectureGM 8A(6036A0003401), PM 12A(6036A0006001)
RAM TypeDDR3_SODIMM0, DDR3_SODIMM1
RAM ArchitectureDDR3 Interface
RAM Quantity / Slots2
LAN ICAR8151, AR8152
WiFi / WLAN ICAtheros
Card Reader ICGL9755
USB Hub ICSN75LVCP412
HDMI Level ShifterW781LHP
Document Number1310A2333201
The Inventec Berlin 10AD motherboard, documented under board number CSA3631 revision X01, is an AMD Danube (Champlain) platform featuring an AMD RS880M/MC GPU with Madison LP graphics architecture. The system supports two DDR3 SODIMM slots utilizing a DDR3 interface. Power management is handled by a MAX_MAX17435ETG+ charging IC in a TQFN-24 package, with charger architecture supporting GM 8A and PM 12A configurations. The embedded controller is a Winbond KBC, and the audio subsystem uses a Conexant CX20671 codec. Networking is provided by Atheros AR8151 and AR8152 LAN controllers alongside an Atheros WLAN module. The board includes a GL9755 card reader, an SN75LVCP412 USB hub, and a W781LHP HDMI level shifter.
A: The board number is CSA3631, revision X01.
A: The embedded controller is a Winbond KBC.
Q: What charging IC and charger architecture does this board use?
A: The charging IC is a MAX_MAX17435ETG+ in a TQFN-24 package, supporting GM 8A and PM 12A charger architectures.
Q: What LAN and WLAN controllers are present?
A: The board uses Atheros AR8151 and AR8152 LAN controllers and an Atheros WLAN module.
  • Toshiba Satellite L650 L650D=BL10ADG 6050A2333101-MB.pdf
