Schematic toshiba satellite l650 l650d bl10adg 6050a2333101-mb-ax1 2009.12.02 schematic
BrandInventec
ModelBerlin 10AD
Motherboard ManufacturerInventec
Project CodeBerlin 10AD
Board NumberCSA3631
RevisionX01
Date2-Dec-2009
CPU PlatformAMD Danube (Champlain)
Document Number1310A2333201
EC / KBCWINBOND
Charging ICMAX_MAX17435ETG+_TQFN_24P
LAN ICAR8151
WiFi / WLAN ICAtheros
Audio CodecCX20671
Card Reader ICGL9755
RAM TypeDDR3_SODIMM0, DDR3_SODIMM1
RAM ArchitectureDDR3 Interface
RAM Quantity / Slots2
GPU TypeRS880M/M
Graphics ArchitectureAMD Madison LP
Charger ArchitectureGM 8A(6036A0003401), PM 12A(6036A0006001)
Power IC(s)SB820M
USB Hub ICSN75LVCP412
HDMI Level ShifterSN75LVCP412
Thermal SensorFAN & THERMAL
The Inventec Berlin 10AD motherboard, documented under board number CSA3631 and revision X01, is built on the AMD Danube (Champlain) platform with an RS880M/M GPU and AMD Madison LP graphics architecture. The system supports two DDR3 SODIMM slots with a DDR3 interface. Power management is handled by an SB820M power IC, with a dual charger architecture consisting of a GM 8A (6036A0003401) and a PM 12A (6036A0006001) configuration. The charging IC is a MAX_MAX17435ETG+ in a TQFN-24 package. The embedded controller is a Winbond KBC, and the audio codec is a Conexant CX20671. Networking is provided by an Atheros WLAN IC and an AR8151 LAN IC. The system includes a GL9755 card reader, an SN75LVCP412 USB hub and HDMI level shifter, and a thermal sensor integrated with the fan controller. The document number is 1310A2333201, dated 2-Dec-2009.
Q: What is the charging architecture on this motherboard?
A: The charging architecture uses a GM 8A (6036A0003401) and a PM 12A (6036A0006001) configuration, with a MAX_MAX17435ETG+ charging IC in a TQFN-24 package.
A: The embedded controller is a Winbond KBC.
Q: What is the GPU and graphics architecture?
A: The GPU is an RS880M/M, and the graphics architecture is AMD Madison LP.
Q: What is the RAM configuration?
A: The motherboard supports two DDR3 SODIMM slots with a DDR3 interface.
  • Toshiba_Satellite_L650_L650D=BL10ADG_6050A2333101-MB-AX1_2009.12.02_DR-BIOS.COM.zip
