toshiba c650 manaus 10ad mas10ad a02 2010.03.17 6050a2357401 1
The Inventec Manaus 10AD motherboard, project code Manaus10AD, board number CSA3431 revision A02, is an AMD Danube (Champlain) platform using a 638 OuPGA S1G4 socket. The system is built around the RS880M GPU and SB820M southbridge. The EC/KBC is a Winbond W781L, and the audio codec is a CX20671. The BIOS is stored on an SPI EEROM. Power management is handled by a MAX17435 charger IC, with a MAX17480 CPU core regulator and multiple TPS51218, TPS51125, TPS51621, TSP51217, G5694F11U, G916T1U, EG2997, AO4406C, and AM3423P power ICs. Memory configuration supports two DDR3 SODIMM slots. Networking is provided by an Atheros AR8152 LAN IC, and wireless connectivity uses an Atheros WLAN module. A Conexant card reader IC is also present.
A: The EC/KBC is a Winbond W781L.
A: The audio codec is a CX20671.
A: The charging IC is a MAX17435.
Q: What LAN IC is used on this motherboard?
A: The LAN IC is an Atheros AR8152.
| Model | Manaus 10AD |
| Motherboard Manufacturer | Inventec |
| Project Code | Manaus10AD |
| Board Number | CSA3431 |
| Revision | A02 |
| Date | 17-Mar-2010 |
| Document Number | 1310A2357401X01 |
| CPU Platform | AMD Danube (Champlain) |
| CPU Socket | 638 OuPGA S1G4 |
| PCH / Southbridge | SB820M |
| GPU Type | RS880M |
| EC / KBC | W781L |
| Audio Codec | CX20671 |
| BIOS / SPI Flash | SPI EEROM |
| LAN IC | AR8152 |
| Charging IC | MAX17435 |
| Power IC(s) | MAX17480, TPS51218, TPS51125, TPS51621, TSP51217, G5694F11U, G916T1U, EG2997, AO4406C, AM3423P |
| RAM Type | DDR3 |
| RAM Architecture | DDR3_SODIMM0, DDR3_SODIMM1 |
| Wireless / WLAN IC | Atheros |
| Card Reader IC | Conexant |
MANAUS10AD
CSA3431
Danube Champlain
638 Oupga S1G4
SB820M
RS880M
W781L
CX20671
AR8152
MAX17435
AM3423P
AO4406C
EG2997
G5694F11U
G916T1U
MAX17480
TPS51125
TPS51218
TPS51621
TSP51217
MANAUS10AD
CSA3431
Danube Champlain
638 Oupga S1G4
SB820M
RS880M
W781L
CX20671
AR8152
MAX17435
AM3423P
AO4406C
EG2997
G5694F11U
G916T1U
MAX17480
TPS51125
TPS51218
TPS51621
TSP51217
