toshiba inventec manaus 10 cs 6050a2355202 schematic
toshiba=1=inventec manaus 10 cs 6050a2355202.pdf
This Inventec Berlin 10 motherboard, project code AX1ES161A3CS and board number CSA3613ESAX1, is built around an Auburndale CPU on a Socket-rPGA989 platform. The system uses DDR3 memory across four slots (DDR3 DIMM0, DIMM1, and two SODIMM slots) operating at 800/1066 MHz. The EC/KBC is an NPCE781LA0DX, and the BIOS is stored on an 8MB SPI Flash. Audio is handled by a Realtek ALC272 codec, and networking by a Realtek RTL8103EL LAN IC. A Realtek RTS5159 card reader is present. The charging subsystem uses a MAX17435ETG+ controller in a TQFN-24 package. Graphics are provided by a GMT 708T1U GPU with CRT output.
A: The board number is CSA3613ESAX1 and the project code is AX1ES161A3CS.
A: The EC/KBC is an NPCE781LA0DX.
Q: What type and capacity is the BIOS flash?
A: The BIOS is an 8MB SPI Flash.
Q: What charging IC is used?
A: The charging IC is a MAX_MAX17435ETG+ in a TQFN-24 package.
Q: What memory architecture does this board support?
A: The board supports DDR3 memory at 800/1066 MHz across four slots: two DDR3 DIMM and two DDR3 SODIMM.
| Brand | Inventec |
| Model | Berlin 10 |
| Project Code | AX1ES161A3CS |
| Board Number | CSA3613ESAX1 |
| Revision | 3A |
| Date | 04-Jan-2010 |
| CPU Platform | Socket-rPGA989 |
| CPU Model | Auburndale |
| PCH / Southbridge | PCH |
| EC / KBC | NPCE781LA0DX |
| Audio Codec | REA_ALC272 |
| BIOS / SPI Flash | SPI Flash 8MB |
| Charging IC | MAX_MAX17435ETG+_TQFN_24 |
| RAM Architecture | DDR3 Interface 800/1066 MHz |
| RAM Quantity / Slots | DDR3 DIMM0, DDR3 DIMM1, DDR3 _SODIMM1, DDR3 _SODIMM3 |
| LAN IC | REA_RTL8103EL |
| Card Reader IC | REA_RTS5159 |
| GPU Type | GMT 708T1U |
| Graphics Architecture | CRT |
AX1ES161A3CS
CSA3613ESAX1
SOCKET-RPGA989
Auburndale
NPCE781LA0DX
REA_ALC272
MAX_MAX17435ETG
_TQFN_24
REA_RTL8103EL
REA_RTS5159
GMT 708T1U
CRT
AX1ES161A3CS
CSA3613ESAX1
SOCKET-RPGA989
Auburndale
NPCE781LA0DX
REA_ALC272
MAX_MAX17435ETG
_TQFN_24
REA_RTL8103EL
REA_RTS5159
GMT 708T1U
CRT
