toshiba c600 inventec manaus 10m 6050a2355301_reva02 schematic
toshiba c600=1=inventec manaus 10m 6050a2355301_reva02.pdf
The INVENTEC MAS10M motherboard, board number 6050A2355301-MB-A02 revision A02 dated 2010-03-16, is built around the Penryn CPU platform paired with the ICH9-M southbridge and integrated Cantiga graphics architecture. System memory consists of two DDR3 SO-DIMM slots operating at 800 MHz or 1066 MHz. The embedded controller is a WINBOND device, and the BIOS is stored on a WINBOND SPI EEROM. Audio is handled by a CX20671 codec, while networking includes an AR8152 LAN controller and an ATHEROS WLAN module. The charging subsystem is managed by a MAX_MAX17435ETG+ in a TQFN-24 package, with power regulation provided by TPS51117, TPS51125, TPS51620, APL5913, G2997, PC6014, PC6014A, M4825, and PAM4825 ICs. Additional integrated controllers include an NPCE781LA0DX card reader, an ICS9LPRS365 USB hub/clock generator, and a dedicated fan and thermal controller.
A: The board number is 6050A2355301-MB-A02, revision A02.
Q: What BIOS IC is used on this motherboard?
A: The BIOS is stored on a WINBOND SPI EEROM.
A: The embedded controller is a WINBOND device.
A: The charging IC is a MAX_MAX17435ETG+ in a TQFN-24 package.
| Brand | INVENTEC |
| Model | MAS10M |
| Motherboard Manufacturer | INVENTEC |
| Project Code | MAS10M |
| Board Number | 6050A2355301-MB-A02 |
| Revision | A02 |
| Date | 2010-03-16 |
| Document Number | A23553-0-0 |
| CPU Platform | Penryn |
| GPU Type | Cantiga |
| Graphics Architecture | Cantiga |
| EC / KBC | WINBOND |
| Audio Codec | CX20671 |
| BIOS / SPI Flash | WINBOND SPI EEROM |
| Charging IC | MAX_MAX17435ETG+_TQFN_24 |
| Charger Architecture | System Charger & |
| Power IC(s) | TPS51117, TPS51125, TPS51620, APL5913, G2997, PC6014, PC6014A, M4825, PAM4825 |
| RAM Architecture | DDR3 Interface |
| LAN IC | AR8152 |
| WiFi / WLAN IC | ATHEROS |
| Card Reader IC | NPCE781LA0DX |
| USB Hub IC | ICS9LPRS365 |
| Thermal Sensor | FAN & THERMAL CONTROLLER |
MAS10M
6050A2355301-MB-A02
Penryn
ICH9
Cantiga
CX20671
MAX_MAX17435ETG
_TQFN_24
APL5913
G2997
M4825
PAM4825
PC6014
PC6014A
TPS51117
TPS51125
TPS51620
AR8152
NPCE781LA0DX
ICS9LPRS365
MAS10M
6050A2355301-MB-A02
Penryn
ICH9
Cantiga
CX20671
MAX_MAX17435ETG
_TQFN_24
APL5913
G2997
M4825
PAM4825
PC6014
PC6014A
TPS51117
TPS51125
TPS51620
AR8152
NPCE781LA0DX
ICS9LPRS365
