toshiba satellite c640 c600 calcutta 10_6050a2357502-mb-a01 schematic
toshiba satellite c640 c600=1=calcutta 10_6050a2357502-mb-a01.pdf
The Inventec Calcutta 10 motherboard, revision A, dated 13-Apr-2010, is built around the Intel Arrandale CPU platform with a Socket-rPGA989 and an HM 55 PCH. The system memory architecture consists of two DDR III SODIMM slots. The embedded controller and Super I/O functions are handled by a WINB781LCX20671. Audio is managed by a CONEXANT codec, while networking is provided by an Atheros WLAN IC and an AR8152-AL1E LAN IC. The charging architecture is a System Charger & DC/DC System power design utilizing a MAX_MAX17435ETG charger IC. The power delivery subsystem includes TPS51218, TPS51621, TPS51125, MAX17480, TSP51217, and G5694F11U ICs. The clock generator is an IDT_ICS9LRS3197AKLFT_MLF_32P. The BIOS is stored in an EEROM SPI flash device.
Q: What is the board number for this motherboard?
A: The board number is 6050A2250801-MB.
A: The EC/KBC is a WINB781LCX20671.
A: The charging IC is a MAX_MAX17435ETG, and the architecture is System Charger & DC/DC System power.
Q: What RAM type and configuration does this board support?
A: The board supports DDR III memory in two SODIMM slots.
| Brand | Inventec |
| Model | Calcutta 10 |
| Project Code | Calcutta 10 |
| Board Number | 6050A2250801-MB |
| Revision | A |
| Date | 13-Apr-2010 |
| CPU Platform | Arrandale |
| CPU Socket | Socket-rPGA989 |
| PCH / Southbridge | HM 55 |
| EC / KBC | WINB781LCX20671 |
| Audio Codec | CONEXANT |
| BIOS / SPI Flash | EEROM |
| Charging IC | MAX_MAX17435ETG |
| Charger Architecture | System Charger & DC/DC System power |
| Power IC(s) | TPS51218, TPS51621, TPS51125, MAX17480, TSP51217, G5694F11U |
| RAM Type | DDR III |
| RAM Architecture | DDR III _SODIMM |
| LAN IC | AR8152-AL1E |
| WiFi / WLAN IC | Atheros |
| Card Reader IC | CARD READER |
| Clock Generator | IDT_ICS9LRS3197AKLFT_MLF_32P |
| Super I/O | WINB781LCX20671 |
6050A2250801-MB
Arrandale
SOCKET-RPGA989
HM-55
WINB781LCX20671
MAX_MAX17435ETG
G5694F11U
MAX17480
TPS51125
TPS51218
TPS51621
TSP51217
AR8152-AL1E
WINB781LCX20671
Super I/O
6050A2250801-MB
Arrandale
SOCKET-RPGA989
HM-55
WINB781LCX20671
MAX_MAX17435ETG
G5694F11U
MAX17480
TPS51125
TPS51218
TPS51621
TSP51217
AR8152-AL1E
WINB781LCX20671
Super I/O
