toshiba c600 c640 calcuta 10 ct10 6050a2357501 cs build rev a01
The Inventec Calcutta 10 motherboard, board number CSA3561 revision A01, is built on the Arrandale CPU platform with an HM 55 PCH and Socket-rPGA989. It features two DDR III SODIMM slots for memory expansion. The system is managed by a WINB781LCX20671 EC/KBC and utilizes an EEROM BIOS/SPI flash. Power management is handled by a MAX17435ETG charger IC alongside multiple power ICs including TPS51125, TPS51621, TPS51218, TSP51217, G5694F11U, PM6652TR, S2997, and AO4406G. Networking is provided by an AR8152-AL1 LAN IC and an Atheros WLAN module. The audio subsystem uses a CONEXANT codec, and clock generation is managed by an IDT_ICS9LRS3197AKLF clock generator. The integrated graphics are based on the Arrandale architecture.
A: The EC/KBC is a WINB781LCX20671.
A: The charging IC is a MAX17435ETG.
A: The motherboard uses DDR III memory in two SODIMM slots (SODIMM0 and SODIMM1).
Q: What LAN and WLAN ICs are used on this motherboard?
A: The LAN IC is an AR8152-AL1, and the WLAN IC is from Atheros.
| Brand | Inventec |
| Model | Calcutta 10 |
| Project Code | Calcutta 10 |
| Board Number | CSA3561 |
| Revision | A01 |
| Date | 22-Mar-2010 |
| CPU Platform | Arrandale |
| CPU Socket | Socket-rPGA989 |
| PCH / Southbridge | HM 55 |
| EC / KBC | WINB781LCX20671 |
| Audio Codec | CONEXANT |
| BIOS / SPI Flash | EEROM |
| Charging IC | MAX17435ETG |
| Charger Architecture | MAX_MAX17435ETG Charger 23 |
| Power IC(s) | TPS51125, TPS51621, TPS51218, TSP51217, G5694F11U, PM6652TR, S2997, AO4406G |
| RAM Type | DDR III |
| RAM Architecture | SODIMM0, SODIMM1 |
| LAN IC | AR8152-AL1 |
| WiFi / WLAN IC | Atheros |
| Clock Generator | IDT_ICS9LRS3197AKLF |
| Card Reader IC | USB7 |
| USB Hub IC | USB11 |
| GPU Type | GM |
| Graphics Architecture | Arrandale |
CSA3561
Arrandale
SOCKET-RPGA989
HM-55
WINB781LCX20671
MAX17435ETG
AO4406G
G5694F11U
PM6652TR
S2997
TPS51125
TPS51218
TPS51621
TSP51217
AR8152-AL1
ICS9LRS3197AKLF
USB7
USB11
GM
(Arrandale
CSA3561
Arrandale
SOCKET-RPGA989
HM-55
WINB781LCX20671
MAX17435ETG
AO4406G
G5694F11U
PM6652TR
S2997
TPS51125
TPS51218
TPS51621
TSP51217
AR8152-AL1
ICS9LRS3197AKLF
USB7
USB11
GM
(Arrandale
