Sony MBX-215 MBX-235 Foxconn M931 Rev SA Schematic
The Foxconn M931 (MBX-215) is a Calpella platform motherboard designed for Arrandale and Clarksfield processors in a Micro-FCPGA-988A socket, paired with the Ibex Peak-M (PM55-B3) PCH. Discrete graphics is provided by an nVIDIA N11P-GE1-A3 or N11M-GE1-A3 dGPU with DDR3 VRAM configurations of 64Mx16bitx8 or 64Mx16bitx4. System management is handled by a Winbond NPCE783L EC/KBC with dedicated 1Mbit SPI firmware, while the system BIOS resides on a 32Mbit SPI flash. The audio subsystem uses a Realtek ALC275-A5 codec, and networking is via a Marvell 88E8057 GbE controller. Power management includes a BQ24753 charger IC and multiple DC/DC converters from Maxim, Texas Instruments, and Semtech. Memory is supported via two DDR3 SO-DIMM slots.
A: The motherboard uses a Winbond NPCE783L EC/KBC with dedicated 1Mbit SPI firmware.
Q: What is the system BIOS configuration?
A: The system BIOS is a 32Mbit SPI flash ROM.
Q: What discrete GPU options are available?
A: The motherboard supports nVIDIA N11P-GE1-A3 or N11M-GE1-A3 discrete graphics with DDR3 VRAM.
Q: What charging IC is used?
A: The charging IC is a BQ24753.
| Brand | Foxconn |
| Model | M931 (MBX-215) |
| Motherboard Manufacturer | HON HAI Precision Ind. Co., Ltd. / Foxconn |
| Project Code | M931 (MBX-215) |
| Board Number | M931 Main Board |
| Revision | SA |
| Date | Wednesday, January 06, 2010 |
| CPU Platform | Arrandale & Clarksfield (SEAM) Processor / Calpella Platform |
| PCH / Southbridge | Ibex Peak-M (PM55-B3) |
| GPU Type | nVIDIA N11P/M Discrete Graphic |
| dGPU Chip Number | nVIDIA N11P-GE1-A3 / N11M-GE1-A3 |
| EC / KBC | Winbond NPCE783L |
| Audio Codec | Realtek ALC275-A5 |
| BIOS / SPI Flash | System BIOS 32M bit X 1 / SPI |
| EC Flash / ROM | EC Firmware 1M bit x1 SPI |
| Charging IC | BQ24753 |
| Power IC(s) | MAX17030, TPS51218, SN0608098, SC412A, MAX17028 |
| RAM Type | DDR(III) |
| RAM Architecture | SO-DIMM 0 / SO-DIMM 1 |
| Card Reader IC | Ricoh R5U231 |
| LAN IC | Marvell 88E8057 |
| WiFi / WLAN IC | Mini-PCIE Card (WLAN) |
| Clock Generator | CK505 SL28748ELC |
| GPU VRAM | DDR3 VRAM 64Mx16bitx8 / 64Mx16bitx4 |
M931
MBX-215
M931 MAIN BOARD
Arrandale
Calpella
Clarksfield
PM55
Graphic
N11P
N11M-GE1-A3
N11P-GE1-A3
NPCE783L
ALC275-A5
BQ24753
MAX17028
MAX17030
SC412A
SN0608098
TPS51218
RICOH R5U231
88E8057
CK505 SL28748ELC
M931
MBX-215
M931 MAIN BOARD
Arrandale
Calpella
Clarksfield
PM55
Graphic
N11P
N11M-GE1-A3
N11P-GE1-A3
NPCE783L
ALC275-A5
BQ24753
MAX17028
MAX17030
SC412A
SN0608098
TPS51218
RICOH R5U231
88E8057
CK505 SL28748ELC
