SONY VPCSB15GB Foxconn MBX-237 V030 Rev 1.3 Schematic
This Foxconn V030 MP MB motherboard, revision 1.3, is built on the Huron River Platform featuring a Sandy Bridge-DC (SNB) processor in a 989 mBGA package paired with an Intel Cougar Point PCH. Discrete graphics is provided by an ATI Whistler or Seymour dGPU with DDR3 VRAM. System management is handled by an SMSC MEC1609 EC with GPIO Expander ECE1099. The system BIOS is a single 32Mbit SPI flash. Audio is driven by a Realtek ALC275 codec with hardware EQ. Memory architecture includes one 204-pin SO-DIMM slot supporting DDR3 at 1066/1333 MHz alongside onboard 2GB or 4GB memory. Charging is managed by a BQ24725 IC. Networking includes a Realtek RTL8111E GbE controller and a Marvell 88E6171RA1-TFJ2C000 LAN hub, with Intel Kilmer Peak WLAN. USB connectivity is expanded by NEC UPD720200F1-DAK-A and UPD720114 hub controllers. A Realtek RTS5209 handles SD/MS card reading. Thermal monitoring uses G709T1UF sensors for CPU and GPU hardware shutdown, plus a W83L771AWG sensor.
A: The motherboard uses an SMSC MEC1609 EC with a separate GPIO Expander ECE1099.
A: The system BIOS is a single 32Mbit SPI flash.
A: The charging IC is a BQ24725
| Brand | FOXCONN |
| Motherboard Manufacturer | HON HAI Precision Ind. Co., Ltd. CCPBG - R&D Division |
| Project Code | V030 MP MB |
| Board Number | V030 MP MB |
| Revision | 1.3 |
| Date | Thursday, January 20, 2011 |
| CPU Platform | Huron River Platform |
| CPU Model | Sandy Bridge-DC (SNB) Processor (35W) |
| CPU Socket | 989 mBGA 25 mm X 25 mm |
| GPU Type | ATI Whistler/Seymour Discrete Graphic |
| dGPU Chip Number | Seymour XTX 512 MB (1Gb x 4) / Whistler LP 1GB/2GB (1Gbx8/2Gbx8) |
| EC / KBC | SMSC MEC1609 w/GPIO Expander ECE1099 |
| Audio Codec | REALTEK ALC275 w/ HWEQ |
| BIOS / SPI Flash | System BIOS 32M bit X 1 |
| Charging IC | BQ24725 |
| RAM Type | DDR(III) |
| RAM Architecture | 204 pin SO-DIMM 0 1066/1333 MHZ / 4GB/2GB On Board |
| Card Reader IC | REALTEK RTS5209 |
| USB Hub IC | NEC UPD720200F1-DAK-A / NEC UPD720114 |
| LAN IC | REALTEK RTL8111E / Marvell 88E6171RA1-TFJ2C000 |
| WiFi / WLAN IC | Intel kilmer peak 2*2 WLAN |
| HDMI Level Shifter | R5G05000N753 |
| Thermal Sensor | G709T1UF (H/W shutdown) For CPU / G709T1UF (H/W shutdown) For GPU / W83L771AWG |
V030
V030 MP MB
Huron River
989 25 MM X 25 MM
ATI Whistler
Graphic
SEYMOUR
(1GBX8
1GBX8/2GBX8
2GBX8)
GPIO EXPANDER ECE1099
MEC1609 W
ALC275 W/ HWEQ
BQ24725
RTS5209
NEC UPD720114
88E6171RA1-TFJ2C000
RTL8111E
R5G05000N753
G709T1UF (H
W83L771AWG
V030
V030 MP MB
Huron River
989 25 MM X 25 MM
ATI Whistler
Graphic
SEYMOUR
(1GBX8
1GBX8/2GBX8
2GBX8)
MEC1609 W
ALC275 W/ HWEQ
BQ24725
RTS5209
NEC UPD720114
88E6171RA1-TFJ2C000
RTL8111E
R5G05000N753
G709T1UF (H
W83L771AWG
