Sony MBX-250 Schematic
This motherboard is built on the Intel Sandy Bridge platform with a Cougar Point PCH, supporting dual-channel DDRIII 1066/1333 memory across two slots. Graphics configuration supports Discrete, UMA, and PX co-lay modes, with an Nvidia N12P discrete GPU option. The system is managed by a Nuvoton NPCE795P EC/KBC controller. Audio is handled by a Realtek ALC271X codec. The BIOS is stored on a 4MB SPI Flash ROM. Power management includes a TI BQ24745RHDR charger IC and multiple DC/DC converters including RT8208BGQW, NCP6131S52MNR, UP6165BQKF, UP6183PQAG, UP6128PQDD, RT9025, NCP5911MNTBG, and APL5916KAI. Networking is provided by a Broadcom BCM57780A1K Gigabit Ethernet controller and 802.11a/b/g wireless. USB 3.0 support is enabled via a uPD720200 hub controller. The card reader is driven by an ENE P2793 controller, with thermal monitoring via an ENE P2800 sensor.
A: The motherboard uses a Nuvoton NPCE795P EC/KBC controller.
A: The BIOS is stored on a 4MB SPI Flash ROM.
Q: What charging IC is used?
A: The charging circuit is built around a Texas Instruments BQ24745RHDR charger IC.
A: Yes, the graphics architecture supports Discrete, UMA, and PX co-lay configurations.
Q: What memory type and configuration is supported?
A: The motherboard supports dual-channel DDRIII 1066/1333 memory across two slots.
| Brand | Nvidia |
| CPU Platform | Intel Sandy Bridge |
| GPU Type | Nvidia N12P (Discrete) |
| Graphics Architecture | Discreet/UMA/PX Co-lay |
| EC / KBC | NPCE795P |
| EC/KBC Manufacturer | NUVOTON |
| Audio Codec | ALC271X |
| BIOS / SPI Flash | SPI Flash ROM 4MB |
| Charging IC | BQ24745RHDR |
| Charger Architecture | TI CHARGER |
| Power IC(s) | RT8208BGQW, NCP6131S52MNR, UP6165BQKF, UP6183PQAG, UP6128PQDD, RT9025, NCP5911MNTBG, APL5916KAI |
| RAM Type | DDRIII 1066/1333 |
| LAN IC | BCM57780A1K |
| USB Hub IC | uPD720200 |
| Card Reader IC | ENE P2793 |
| Thermal Sensor | ENE P2800 |
| HDMI Level Shifter | Level shifter |
Sandy Bridge
N12P
NPCE795P
ALC271X
BQ24745RHDR
APL5916KAI
NCP5911MNTBG
NCP6131S52MNR
RT8208BGQW
RT9025
UP6128PQDD
UP6165BQKF
UP6183PQAG
BCM57780A1K
UPD720200
P2793
P2800
Sandy Bridge
N12P
NPCE795P
ALC271X
BQ24745RHDR
APL5916KAI
NCP5911MNTBG
NCP6131S52MNR
RT8208BGQW
RT9025
UP6128PQDD
UP6165BQKF
UP6183PQAG
BCM57780A1K
UPD720200
P2793
P2800
