sony wistron z40hr_mbx-250_rev0.7 schematic
sony=1=wistron z40hr_mbx-250_rev0.7.pdf
This motherboard is built on the Intel Sandy Bridge platform with a Cougar Point PCH, supporting DDRIII 1066/1333 memory across two dual-channel slots. Graphics are handled by an Nvidia N12PENE P2800 discrete GPU, with the board supporting Discreet/UMA/PX co-lay configuration for potential dGPU to UMA conversion. System management is provided by a Nuvoton NPCE795P EC/KBC, while audio is managed by a Realtek ALC271X codec. The BIOS is stored on a 4MB SPI flash ROM. Power management includes a TI BQ24745RHDR charger and multiple DC/DC converters including RT8208BGQW, NCP6131S52MNR, UP6165BQKF, UP6183PQAG, UP6128PQDD, RT9025, NCP5911MNTBG, and APL5916KAI. Networking is handled by a Broadcom BCM57780A1K Gigabit Ethernet controller, with 802.11a/b/g wireless support. The board also features a uPD720200 USB 3.0 hub controller and a multi-format card reader supporting SD/MMC+/MS/MS Pro/xD.
A: The motherboard uses a Nuvoton NPCE795P EC/KBC.
A: The BIOS is stored on a 4MB SPI flash ROM.
A: Yes, the board supports Discreet/UMA/PX co-lay configuration, allowing for dGPU to UMA conversion.
Q: What charging IC is used?
A: The charging IC is a Texas Instruments BQ24745RHDR.
A: The board supports DDRIII 1066/1333 memory in a dual-channel configuration across two slots.
| Brand | Nvidia |
| CPU Platform | Intel Sandy Bridge |
| CPU Socket | FSB: 1066 MHz |
| GPU Type | Nvidia N12PENE P2800 |
| Graphics Architecture | Discreet/UMA/PX Co-lay |
| EC / KBC | NPCE795P |
| EC/KBC Manufacturer | NUVOTON |
| Audio Codec | ALC271X |
| BIOS / SPI Flash | SPI Flash ROM 4MB |
| Charging IC | BQ24745RHDR |
| Charger Architecture | TI CHARGER |
| Power IC(s) | RT8208BGQW, NCP6131S52MNR, UP6165BQKF, UP6183PQAG, UP6128PQDD, RT9025, NCP5911MNTBG, APL5916KAI |
| RAM Type | DDRIII 1066/1333 |
| LAN IC | BCM57780A1K |
| Card Reader IC | SD/MMC+/MS/MS Pro/xD |
| USB Hub IC | uPD720200 |
| GPU Chip Number | Nvidia N12PENE P2800 |
| dGPU Chip Number | Nvidia N12PENE P2800 |
| dGPU to UMA Conversion Support | Discreet/UMA/PX Co-lay |
Sandy Bridge
FSB 1066 MHZ
N12PENE P2800
NPCE795P
ALC271X
BQ24745RHDR
APL5916KAI
NCP5911MNTBG
NCP6131S52MNR
RT8208BGQW
RT9025
UP6128PQDD
UP6165BQKF
UP6183PQAG
BCM57780A1K
UPD720200
N12PENE P2800
Sandy Bridge
FSB 1066 MHZ
N12PENE P2800
NPCE795P
ALC271X
BQ24745RHDR
APL5916KAI
NCP5911MNTBG
NCP6131S52MNR
RT8208BGQW
RT9025
UP6128PQDD
UP6165BQKF
UP6183PQAG
BCM57780A1K
UPD720200
N12PENE P2800
