sony foxconn m930_irx-5100_mbx-215_revsb schematic
sony=1=foxconn m930_irx-5100_mbx-215_revsb.pdf
The Foxconn M930 (MBX-215) is a Calpella platform motherboard designed for Arrandale and Clarksfield processors with an Ibex Peak-M (PM55/PM57-B3) PCH. Graphics are handled by discrete nVIDIA N11P-GE1 or N11M-GE1 GPUs with dedicated DDR3 VRAM. The system BIOS is a 32Mbit SPI flash, while the EC firmware is a separate 1Mbit SPI ROM for the Winbond NPCE783L EC/KBC. Power management is distributed across multiple ICs including the MAX17030 CPU DC/DC converter, TPS51218 system DC/DC converters, BQ24753 charger, SN0608098, SC412A, and MAX17028. Audio is provided by a Realtek ALC275 codec, and networking by a Marvell 88E8057 GbE controller. Memory is supported via two DDR3 SO-DIMM slots, and a Ricoh R5U231 card reader handles i.LINK, MS Duo, and SD cards.
A: The motherboard uses a Winbond NPCE783L EC/KBC with dedicated 1Mbit SPI EC firmware flash.
Q: What is the system BIOS configuration?
A: The system BIOS is a single 32Mbit SPI flash ROM.
Q: What discrete GPU options are available?
A: The motherboard supports nVIDIA N11P-GE1 or N11M-GE1 discrete graphics with dedicated DDR3 VRAM.
A: The charging IC is a BQ24753.
| Brand | FOXCONN |
| Model | M930 (MBX-215) |
| Motherboard Manufacturer | HON HAI Precision Ind. Co., Ltd. / CCPBG - R&D Division |
| Project Code | M930 (IRX-5100) |
| Board Number | M930 Main Board |
| Date | Wednesday, August 12, 2009 |
| CPU Platform | Arrandale & Clarksfield (SEAM) Processor / Calpella Platform |
| PCH / Southbridge | Ibex Peak-M (PM55/PM57-B3) |
| GPU Type | nVIDIA N11P/M Discrete Graphic |
| dGPU Chip Number | N11P-GE1 / N11M-GE1 |
| EC / KBC | Winbond NPCE783L |
| Audio Codec | Realtek ALC275 |
| BIOS / SPI Flash | System BIOS 32M bit X 1 / SPI |
| EC Flash / ROM | EC Firmware 1M bit x1 / SPI |
| Charging IC | BQ24753 |
| Power IC(s) | MAX17030, TPS51218, SN0608098, SC412A, MAX17028 |
| RAM Type | DDR(III) |
| RAM Architecture | SO-DIMM 0 / SO-DIMM 1 |
| Card Reader IC | Ricoh R5U231 |
| LAN IC | Marvell 88E8057 |
| WiFi / WLAN IC | Mini-PCIE Card (WLAN) |
| Thermal Sensor | W83L771AWG |
IRX-5100
M930
M930 MAIN BOARD
Arrandale
Calpella
Clarksfield
PM55
PM57
Graphic
N11P
N11M-GE1
N11P-GE1
NPCE783L
ALC275
BQ24753
MAX17028
MAX17030
SC412A
SN0608098
TPS51218
RICOH R5U231
88E8057
W83L771AWG
IRX-5100
M930
M930 MAIN BOARD
Arrandale
Calpella
Clarksfield
PM55
PM57
Graphic
N11P
N11M-GE1
N11P-GE1
NPCE783L
ALC275
BQ24753
MAX17028
MAX17030
SC412A
SN0608098
TPS51218
RICOH R5U231
88E8057
W83L771AWG
