MSI MS-9145 Rev 100 110 200 300 0A 20a 0d 0c 20a 30a Schematic
The Micro-Star MS-9145 Dual K8 1U System, revision 0A01 dated 03/17/2003, is a server motherboard designed for dual AMD Sledgehammer DP processors. The platform utilizes a 128-bit Registered DDR memory architecture across four DIMM slots, operating at 200-333 MHz. Graphics are handled by an ATI Rage XL controller, while networking is provided by a Broadcom BCM5704C Gigabit Ethernet controller. Storage connectivity includes an LSI 53C1020C SCSI controller. The system employs a Golem PCI-X bridge, a Thor HT bridge, and an 8131 HT link bridge for interconnect. The Super I/O is a PC87366, and hardware monitoring is managed by an ADM1027. The BIOS is stored on an LPC ROM located at page 40 of the schematic.
A: The board number is MS-9145, revision 0A01.
Q: What CPU platform does this motherboard support?
A: This motherboard supports dual AMD Sledgehammer DP processors.
Q: What type of memory architecture is used?
A: The motherboard uses a 128-bit Registered DDR memory architecture across four DIMM slots.
Q: Where is the BIOS flash ROM located in the schematic?
A: The BIOS is stored on an LPC ROM, referenced on schematic page 40 LPC ROM.
The Micro-Star MS-9145 Dual K8 1U System is a server motherboard designed for dual AMD Sledgehammer DP processors. The platform utilizes an 8111 southbridge and supports up to six registered DDR DIMMs across both CPU channels, with 128-bit memory architecture operating at 200-333 MHz. Graphics are handled by an ATI Rage XL controller. The system integrates a Broadcom BCM5704C dual Gigabit Ethernet controller and an LSI 53C1020 SCSI controller for storage. The EC/KBC function is managed by an NS/PC87366 Super I/O, and system monitoring is provided by an ADM1027 thermal sensor. The BIOS is stored on a Flash ROM accessible via the LPC bus. The board also features dual PCI-X slots driven by Golem bridge controllers and a Thor bridge for legacy I/O including AC97, USB, and IDE.
A: The board number is MS-9145, with revision 0C dated 92/06/16.
A: It supports registered DDR memory with a 128-bit architecture, using 4 DIMMs for CPU0 and 2 DIMMs for CPU1.
Q: What LAN controller is used on this board?
A: The board uses a Broadcom BCM5704C dual Gigabit Ethernet controller.
Q: What Super I/O or EC/KBC chip is present?
A: The system uses an NS/PC87366 Super I/O for keyboard, mouse, and serial port control.
The MSI MS-9145 is a dual K8 1U server motherboard based on the Sledgehammer DP platform, revision 1.00, dated August 6, 2003. It features two CPU sockets supporting HyperTransport at 1600 MT/s and 400 MT/s, with the 8111 southbridge providing HT links. Memory architecture includes four registered DDR DIMM slots for CPU0 operating at 128-bit width and two registered DDR DIMM slots for CPU1 at 64-bit width, supporting 200-333 MHz speeds. Graphics are handled by an ATI Rage XL controller. Networking is provided by a Broadcom BCM5704C dual-port Gigabit Ethernet controller. Storage connectivity includes an LSI 53C1020C SCSI controller and an EIDE ATA/100 interface. The system uses an LPC ROM for firmware storage. Power management is handled by multiple ICs including ISL6559CB, ISL6522CB, ISL6225, LM2575T-12, LX8384, and RC1117S. The board also integrates a PC87366 Super I/O and an ADM1027 hardware monitor. Three BOM variants are documented: MS9145I1-0D, MS9145-0D Standard with SCSI, and MS9145-0D Option A without SCSI.
A: The board number is MS-9145, revision 1.00, dated August 6, 2003.
A: It supports a dual K8 Sledgehammer DP platform with HyperTransport links at 1600 MT/s and 400 MT/s.
A: The board uses registered DDR memory with 128-bit width for CPU0 across 4 DIMM slots and 64-bit width for CPU1 across 2 DIMM slots, supporting 200-333 MHz.
Q: What are the BOM variants available for this motherboard?
A: Three BOM variants are documented: MS9145I1-0D (9145-D10), MS9145-0D Standard with SCSI (9145-D20), and MS9145-0D Option A without SCSI (9145-D30).
The Micro-Star MS-9145 is a dual K8 1U server motherboard dated October 20, 2003, revision 1.10. It supports dual Sledgehammer DP processors with HyperTransport links at 1600 MT/s. The platform uses an 8111 southbridge and a Golem PCI-X bridge architecture. Memory architecture consists of four registered DDR DIMMs on CPU0 operating at 128-bit width and two registered DDR DIMMs on CPU1 at 64-bit width, supporting 200-333 MHz. Graphics are handled by an ATI Rage XL controller. Networking is provided by a Broadcom BCM5704C dual Gigabit Ethernet controller. Storage connectivity includes an LSI 53C1020C SCSI controller and an IDE ATA/100 interface. The system is managed by a PC87366 Super I/O and an ADM1027 hardware monitor. Power regulation is handled by multiple ICs including ISL6522CB, ISL6559CB, ISL6225, LM2575T-12, and LX8384.
A: The board number is MS-9145, revision 1.10, dated October 20, 2003.
A: It supports dual AMD K8 Sledgehammer DP processors with HyperTransport links at 1600 MT/s.
Q: What memory configuration is used on this board?
A: CPU0 supports four registered DDR DIMMs at 128-bit width, and CPU1 supports two registered DDR DIMMs at 64-bit width, operating at 200-333 MHz.
Q: What LAN controller is used?
Q: What SCSI controller is present?
A: The board includes an LSI 53C1020C SCSI controller.
The MS-9145 Dual K8 1U System is a server motherboard from Micro-Star Int'l Co., Ltd., documented under revision 1.10 dated December 11, 2003. It supports dual AMD K8 Sledgehammer processors with HyperTransport connectivity, utilizing an AMD 8111 southbridge and an AMD 8131 PCI-X tunnel for bridge and slot expansion. The board features four registered DDR DIMM slots on a 128-bit memory bus for CPU0 and two registered DDR DIMM slots on a 64-bit bus for CPU1, operating at 200-333 MHz. Integrated graphics is handled by an ATI Rage XL controller, while networking is provided by a Broadcom BCM5704 Gigabit Ethernet controller. Storage connectivity includes an LSI 53C1020 SCSI controller and an EIDE ATA/100 interface. Voltage regulation is managed by ISL6559CB for CPU core, ISL6522CB for DDR memory, ISL6225 for VLDT, and LX8384 for 1.8V, with additional regulation from LM2575T-12 for 3.3V and -12V rails. System monitoring is performed by an ADM1027 hardware monitor IC, and the Super I/O is an NS/PC87366.
A: The board number is MS-9145, revision 1.10, dated December 11, 2003.
A: It supports dual AMD K8 Sledgehammer processors with HyperTransport connectivity.
Q: What memory architecture is used on this motherboard?
A: CPU0 supports four registered DDR DIMMs on a 128-bit bus, while CPU1 supports two registered DDR DIMMs on a 64-bit bus, operating at 200-333 MHz.
Q: What are the key voltage regulator ICs on this motherboard?
A: CPU core voltage is regulated by ISL6559CB, DDR voltage by ISL6522CB, VLDT by ISL6225, and 1.8V by LX8384.
The MSI MS-9145 is a dual K8 1U server motherboard based on the Sledgehammer DP platform, dated 2003/11/14 with revision 2000. The board supports two AMD Opteron processors connected via HyperTransport at 1600 MT/s. Memory architecture consists of four registered DDR DIMM slots for CPU0 operating on a 128-bit bus and two registered DDR DIMM slots for CPU1 on a 64-bit bus, supporting 200-333 MHz memory. The system uses an 8111 southbridge and a 8131 HyperTransport bridge for PCI-X connectivity. Integrated graphics is provided by an ATI Rage XL controller. Networking is handled by a Broadcom BCM5704CB dual-port Gigabit Ethernet controller. Storage connectivity includes an LSI 53C1020C SCSI controller and an IDE ATA/100 interface. Voltage regulation is managed by multiple controllers including ISL6559CB for CPU core voltages, ISL6522CB for DDR memory, ISL6225 for VLDT 1.2V, LX8384 for 1.8V, and LM2575T-12 for -12V generation. The system incorporates a PC87366 Super I/O and an ADM1027 hardware monitor. The board supports both SCSI and IDE (non-SCSI) configurations as documented in the BOM variants.
A: The board number is MS-9145 with revision 2000, dated 2003/11/14.
A: This is a Dual K8 1U system supporting two Sledgehammer DP (AMD Opteron) processors.
A: CPU0 supports four registered DDR DIMM slots on a 128-bit bus, and CPU1 supports two registered DDR DIMM slots on a 64-bit bus, operating at 200-333 MHz.
Q: What LAN controller is used on this motherboard?
A: The board uses a
The MSI MS-9145 Dual K8 1U System is a server motherboard designed for dual AMD Sledgehammer DP processors. It features a 8111 southbridge and utilizes registered DDR memory architecture with 4 DIMM slots for CPU0 and 2 DIMM slots for CPU1. The board integrates an ATI Rage XL GPU for basic graphics output and a Broadcom BCM5704CB dual-port Gigabit Ethernet controller. Storage connectivity is provided by an LSI 53C1020C SCSI controller and an IDE ATA/100 interface. Power regulation is handled by multiple dedicated controllers including ISL6559CB for CPU Vcore, ISL6522CB for DDR VDIMM, ISL6225 for VLDT 1.2V, and LX8384 for 1.8V. The system also includes a PC87366 Super I/O, an ADM1027 hardware monitor, and an LPC Flash ROM for BIOS storage. The board revision is 2000 with a date of 2003/09/03.
A: The board number is MS-9145 with revision 2000, dated 2003/09/03.
A: It supports dual AMD Sledgehammer DP processors with HyperTransport connections.
A: It uses registered DDR memory with 128-bit architecture for CPU0 (4 DIMMs) and 64-bit architecture for CPU1 (2 DIMMs).
Q: What LAN controller is integrated on this motherboard?
A: The board integrates a Broadcom BCM5704CB dual-port Gigabit Ethernet controller.
Q: What type of storage controllers are present on this motherboard?
A: It includes an LSI 53C1020C SCSI controller and an
This MSI MS-9145 Dual K8 1U System motherboard, revision 20A dated 2004/02/18, is designed for dual AMD Sledgehammer DP processors. The platform utilizes an 8111 southbridge and supports up to four registered DDR DIMMs in a 128-bit architecture. Graphics are handled by an ATI Rage XL controller. Networking is provided by a Broadcom BCM5704C Gigabit Ethernet controller, while storage connectivity includes an LSI 53C1020C SCSI controller. The system incorporates a PC87366 Super I/O and an ADM1027 hardware monitor. Power regulation is managed by a combination of ISL6522CB, ISL6559CB, ISL6225, LX8384, and LM2575T-12 ICs. The board supports multiple PCB versions including 1.00, 1.10, 1.20, 2.00, and 2.0A, with corresponding IBM and MSI Channel configuration variants.
A: The board number is MS-9145, revision 20A.
A: This motherboard supports a Dual K8 1U System with AMD Sledgehammer DP processors.
A: The motherboard uses registered DDR memory in a 128-bit architecture, with support for up to 4 DDR DIMMs.
A: The LAN controller is a Broadcom BCM5704C.
The MSI MS-9145 is a dual K8 1U server motherboard, revision 20A01, dated 2004/02/18. It supports dual AMD Sledgehammer DP processors with HyperTransport links. The platform uses an 8111 southbridge and an 8131 HT bridge for I/O connectivity. Graphics are handled by an ATI Rage XL controller. Networking is provided by a Broadcom BCM5704C dual Gigabit Ethernet controller. Storage includes an LSI 53C1020C SCSI controller and an IDE ATA/100 interface. The system features six DDR DIMM slots, with four dedicated to CPU0 and two to CPU1, supporting registered DDR memory. Voltage regulation is managed by multiple ISL6559CB, ISL6522CB, ISL6225, LM2575T-12, LX8384, and RC1117S regulators. The Super I/O is a PC87366, and hardware monitoring is handled by an ADM1027. The system includes an LPC Flash ROM for firmware storage.
A: The board number is MS-9145, revision 20A01.
A: It supports registered DDR memory across six DIMM slots, with four slots for CPU0 and two slots for CPU1.
A: The LAN controller is a Broadcom BCM5704C dual Gigabit Ethernet controller.
The MS-9145 is a Micro-Star International dual K8 1U server motherboard revision 3.0C1, dated 2004/05/04. It supports dual Sledgehammer DP processors with registered DDR memory across four DIMM slots operating at 128-bit width and 200-400 MHz. The platform utilizes an AMD 8111 southbridge and an AMD 8131 HyperTransport bridge, with Golem and Thor bridges managing PCI-X and legacy I/O. Graphics are handled by an ATI Rage XL controller. Networking is provided by a Broadcom BCM5704C Gigabit Ethernet controller. Storage includes an LSI 53C1020 SCSI controller and a Sil3512 SATA controller. System management is handled by an NS/PC87366 Super I/O and an ADM1027 hardware monitor. Core voltage regulation for both CPUs is managed by ISL6559CB controllers, with DDR, VLDT, and auxiliary rails regulated by ISL6522CB, ISL6225, LX8384, and LM2575T-12 devices.
A: The board number is MS-9145 with revision 3.0C1.
A: This motherboard supports a dual K8 1U system with Sledgehammer DP processors.
Q: What type of memory is used on this motherboard?
A: The motherboard uses registered DDR memory across four DIMM slots, operating at 128-bit width and 200-400 MHz.
A: CPU Vcore is regulated by ISL6559CB controllers, DDR by ISL6522CB, VLDT 1.2V by ISL6225, 1.8V by LX8384, and
The MS-9145 is a Micro-Star International dual K8 1U server motherboard designed for the Sledgehammer DP platform. The board is built around two AMD Opteron processors with registered DDR memory support across four DIMM slots operating at 128-bit width and 200-400 MHz speeds. The platform uses an AMD 8111 southbridge paired with an AMD 8131 HyperTransport bridge for CPU-to-chipset connectivity. Graphics are handled by an ATI Rage XL controller, while networking is provided by a Broadcom BCM5704C dual-port Gigabit Ethernet controller. Storage connectivity includes an LSI 53C1020 SCSI controller and a Sil3512 SATA controller. The system is managed by an NS/PC87366 Super I/O and an ADM1027 hardware monitor. Power regulation is handled by multiple ISL6522CB, ISL6559CB, ISL6225, LX8384, and LM2575T-12 voltage regulators. The board includes an LPC Flash ROM for BIOS storage and features dual Golem PCI-X bridges for expansion slot support.
A: The board number is MS-9145 with revision 3.0C1, dated 2004/05/04.
A: This is a dual K8 1U system supporting two Sledgehammer DP (AMD Opteron) processors.
A: The board uses registered DDR memory across four DIMM slots, operating at 128-bit width with speeds from 200 to 400 MHz.
Q: What are the key controllers on this motherboard?
A: The board features an AMD 8111 southbridge, AMD 8131 HT bridge, Broadcom BCM5704C dual-port Gigabit
This MSI MS-9145 motherboard is a Dual K8 1U System designed for dual AMD Sledgehammer DP processors. The platform utilizes an 8131 HT bridge for CPU HT link connections, with additional Golem and Thor bridges for PCI-X and peripheral connectivity. Graphics are handled by an ATI Rage XL controller. Networking is provided by a Broadcom BCM5704C Gigabit Ethernet controller, and SCSI functionality is managed by an LSI 53C1020C controller. The system uses four DDR Registered DIMM slots for memory. Voltage regulation is handled by multiple ICs including ISL6559CB for CPU core voltages, ISL6522CB for DDR power, ISL6225 for VLDT1.2, LX8384 for 1.8V, and LM2575T-12 for -12V generation. The SIO is a PC87366, and hardware monitoring is managed by an ADM1027 IC. The board revision is 0D, dated 08/05/2003.
A: The board number is MS-9145, revision 0D, dated 08/05/2003.
A: This motherboard supports a Dual K8 1U System with dual AMD Sledgehammer DP processors.
A: The motherboard uses four DDR Registered DIMM slots.
Q: What LAN and SCSI controllers are present on this motherboard?
A: The LAN controller is a Broadcom BCM5704C, and the SCSI controller is an LSI 53C1020C.
The MSI MS-9145 is a Dual K8 1U System motherboard revision 3.0A, dated 2004/05/04, manufactured by Micro-Star Int'l Co., Ltd. It supports dual AMD Sledgehammer DP processors with registered DDR memory across four DIMM slots. The platform utilizes an AMD 8111 southbridge and features an ATI Rage XL GPU for onboard graphics. Networking is handled by a Broadcom BCM5704C Gigabit Ethernet controller. Storage connectivity includes an LSI 53C1020C SCSI controller and a Sil3512 SATA controller. System management is provided by an NS/PC87366 Super I/O and an ADM1027 hardware monitor. Power regulation is managed by multiple ICs including ISL6559CB, ISL6522CB, ISL6225, RC1117, and LM2575T-12.
A: The board number is MS-9145, revision 3.0A.
A: The motherboard uses registered DDR memory across four DIMM slots.
A: The motherboard uses a Broadcom BCM5704C Gigabit Ethernet controller.
This MSI motherboard schematic, dated Tuesday, July 29, 2003, is marked as confidential for internal use only. The platform utilizes a ZIRCON UL95 EC/KBC, located at U1, which manages power button and system power-on signal routing. The schematic details the PS_ON# signal connection, power button input and output paths, and system power-on input and output signals. The design includes SO-DIMM connector interfaces for power button and system power-on signals, as well as front panel connector circuits operating at 3.3V and 5V voltage levels. The document number and revision code are present on the schematic title block.
A: The EC/KBC is a ZIRCON UL95, located at U1.
Q: What is the date of this schematic?
A: The schematic is dated Tuesday, July 29, 2003.
| Brand | Micro-Star Int'l Co., Ltd. |
| Model | MS-9145 Dual K8 1U System |
| Board Number | MS-9145 |
| Revision | 0A01 |
| Date | 03/17/2003 |
| CPU Platform | Dual K8 [URL="https://dr-bios.com/components/cpu-platform/sledgehammer-dp/"]Sledgehammer DP[/URL] |
| CPU Model | Sledgehammer DP |
| PCH / Southbridge | 8111 |
| GPU Type | ATI Rage XL |
| LAN IC | BCM5704C |
| SCSI Controller | LSI 53C1020C |
| Super I/O | PC87366 |
| Hardware Monitor | ADM1027 |
| RAM Type | ddr/"]Registered DDR[/URL] |
| RAM Architecture | 128 bit |
| RAM Quantity / Slots | 4 DDR DIMM |
| PCI-X Bridge | Golem |
| HT Bridge | Thor |
| HT Link Bridge | 8131 |
| Flash ROM | LPC ROM |
| LPC ROM Location | 40 LPC ROM |
| Revision | 0C 92/06/16 |
| Date | 05/09/2003 |
| EC / KBC | NS/PC87366 |
| BIOS / SPI Flash | Flash ROM |
| RAM Quantity / Slots | 4 DDR DIMM (CPU0) + 2 DDR DIMM (CPU1) |
| LAN IC | BCM5704C |
| WiFi / WLAN IC | Broadcom GbE |
| Card Reader IC | LSI 53C1020 |
| Thermal Sensor | ADM1027 |
| Brand | MSI (Micro-Star Int'l Co., Ltd.) |
| Model | MS-9145 |
| Revision | 1.00 |
| Date | 08/06/2003 |
| CPU Platform | Dual K8 (Sledgehammer DP) |
| LAN IC | BCM5704C (Broadcom GbE) |
| SIO | PC87366 |
| RAM Architecture | 128-bit (CPU0), 64-bit (CPU1) |
| RAM Quantity / Slots | 4 DDR DIMMs (CPU0), 2 DDR DIMMs (CPU1) |
| Charging IC | ISL6559CB |
| Power IC(s) | ISL6522CB, ISL6225, LM2575T-12, LX8384, RC1117S |
| BOM | MS9145I1-0D => 9145-D10, MS9145-0D Standard (W SCSI) => 9145-D20, MS9145-0D Option: A (W/O SCSI) => 9145-D30 |
| Motherboard Manufacturer | Micro-Star Int'l Co., Ltd. |
| Revision | 1.10 |
| Date | Monday, October 20, 2003 |
| LAN IC | BCM5704C |
| SIO | PC87366 |
| Power IC(s) | ISL6522CB, ISL6559CB, ISL6225, LM2575T-12, LX8384 |
| RAM Architecture | 128 bit (CPU0), 64 bit (CPU1) |
| Document Number | MS-9145 |
| Revision | 1.10 |
| Date | 2003/12/11 |
| CPU Platform | Dual AMD K8 ([URL="https://dr-bios.com/components/cpu-platform/sledgehammer-dp/"]Sledgehammer DP)[/URL] |
| PCH / Southbridge | AMD 8111 |
| LAN IC | Broadcom BCM5704 |
| SCSI Controller | LSI 53C1020 |
| SIO / Super I/O | NS/PC87366 |
| Hardware Monitor IC | ADM1027 |
| CPU Voltage Regulator | ISL6559CB |
| DDR Voltage Regulator | ISL6522CB |
| VLDT Voltage Regulator | ISL6225 |
| 1.8V Regulator | LX8384 |
| 3.3V/-12V Regulator | LM2575T-12 |
| Document Number | MS9145I1-0D, MS9145I1-100, MS9145I1-110 |
| Model | MS-9145 |
| Revision | 2000 |
| Date | 2003/11/14 |
| CPU Platform | [URL="https://dr-bios.com/components/cpu-platform/dual-k8-1u-system/"]Dual K8 1U System (Sledgehammer DP)[/URL] |
| LAN IC | BCM5704CB (Broadcom GbE) |
| Voltage Regulator (CPU0 Vcore) | ISL6559CB |
| Voltage Regulator (CPU1 Vcore) | ISL6559CB |
| Voltage Regulator (DDR) | ISL6522CB |
| Voltage Regulator (VLDT 1.2V) | ISL6225 |
| Voltage Regulator (1.8V) | LX8384 |
| Voltage Regulator (-12V) | LM2575T-12 |
| Document Number | MS9145I1-0D, MS9145-0D, MS9145I1-100, MS9145-100 |
A: The board uses a
| Model | MS-9145 |
| Project Code | MS-9145 Dual K8 1U System |
| Revision | 2000 |
| Date | 2003/09/03 |
| CPU Platform | [URL="https://dr-bios.com/components/cpu-platform/sledgehammer-dp/"]Sledgehammer DP (Dual Processor)[/URL] |
| Voltage Regulator (DDR VDIMM) | ISL6522CB |
| Clock Synthesizer | ICS (implied by page 17) |
| Flash ROM | LPC ROM (page 40) |
| Brand | MSI |
| Model | MS-9145 |
| Revision | 20A |
| Date | 2004/02/18 |
| CPU Platform | Dual K8 1U System |
| LAN IC | BCM5704C |
| Audio Codec | THOR AC97 |
| Card Reader IC | LSI 53C1020C |
| Power IC(s) | ISL6522CB, ISL6559CB, ISL6225, LX8384, LM2575T-12 |
| Charging IC | ISL6522CB |
| Brand | MSI |
| Model | MS-9145 |
| Revision | 20A01 |
| Date | 2004/02/18 |
| LAN IC | BCM5704C |
| Voltage Regulator (P0_VDIMM_2.5V) | ISL6522CB |
| Voltage Regulator (P1_VDIMM_2.5V) | ISL6522CB |
| Voltage Regulator (P0_VTT_1.25V) | ISL6522CB |
| Voltage Regulator (P1_VTT_1.25V) | ISL6522CB |
| Voltage Regulator (VLDT) | ISL6225 |
| Voltage Regulator (+1.8VDUAL) | LX8384 |
| Voltage Regulator (+2.5V) | RC1117S |
| RAM Architecture | Registered |
| Clock Generator | ICS 169 |
| Flash ROM | LPC Flash ROM |
| Model | MS-9145 |
| Revision | 3.0C1 |
| Date | 2004/05/04 |
| CPU Platform | Dual K8 1U System / Sledgehammer DP |
| LAN IC | Broadcom BCM5704C |
| SATA Controller | Sil3512 |
| Super I/O | pc87366/"]NS/PC87366[/URL] |
| Voltage Regulator (3.3V) | LM2575T-12 |
| RAM Quantity / Slots | 4 DDR DIMMs |
| RAM Architecture | 128 bit, 200-400 MHz |
| HT Bridge | AMD 8131 |
| HT Bridge | Golem (PCI-X Bridge) |
| HT Bridge | Thor |
| PCB Version | 3.00 |
| Model | MS-9145 |
| Revision | 3.0C1 |
| Date | 2004/05/04 |
| RAM Type | ddr-registered/"]DDR Registered[/URL] |
| HT Bridge (Golem) | Golem PCI-X Bridge A, Golem PCI-X Bridge B |
| Clock Synthesizer | ICS (implied by block diagram) |
| Brand | MSI |
| Model | MS-9145 |
| Revision | 0D |
| Date | 08/05/2003 |
| LAN IC | BCM5704C |
| SIO | PC87366 |
| Voltage Regulator IC (CPU0 Vcore) | ISL6559CB |
| Voltage Regulator IC (CPU1 Vcore) | ISL6559CB |
| Voltage Regulator IC (DDR) | ISL6522CB |
| Voltage Regulator IC (VLDT1.2) | ISL6225 |
| Voltage Regulator IC (1.8V) | LX8384 |
| Voltage Regulator IC (-12V) | LM2575T-12 |
| HT Bridge | 8131 |
| HT Bridge | Golem |
| HT Bridge | Thor |
| Document Number | MS9145I1-0D |
| Brand | MSI |
| Model | MS-9145 |
| Revision | 3.0A |
| Date | 2004/05/04 |
| LAN IC | BCM5704C |
| Power IC(s) | ISL6522CB, ISL6225, RC1117, LM2575T-12 |
| Brand | MSI |
| Date | Tuesday, July 29, 2003 |
| EC / KBC | ZIRCON UL95 |
| EC/KBC Package | U1 |
MS-9145
Dual K8 Sledgehammer DP
Sledgehammer DP
8111
ATI Rage XL
BCM5704C
53C1020C
Storage Controller
PC87366
Super I/O
ADM1027
REGISTERED DDR
NS/PC87366
53C1020
ISL6559CB
ISL6225
ISL6522CB
LM2575T-12
LX8384
RC1117S
ISL6559CB
Dual AMD K8 Sledgehammer DP
BCM5704
53C1020
Storage Controller
Dual K8 1U System Sledgehammer DP
BCM5704CB
MS-9145
Sledgehammer DP Dual
Dual K8 1U System
THOR AC97
53C1020C
ISL6522CB
DDR
ICS169
Sledgehammer DP
SIL3512
Storage Controller
NS/PC87366
Super I/O
8131
Northbridge / MCH
DDR REGISTERED
RC1117
ZIRCON UL95
MS-9145
Sledgehammer DP
8111
ATI Rage XL
BCM5704C
53C1020C
Storage Controller
PC87366
Super I/O
ADM1027
REGISTERED DDR
NS/PC87366
53C1020
ISL6559CB
ISL6225
ISL6522CB
LM2575T-12
LX8384
RC1117S
ISL6559CB
BCM5704
53C1020
Storage Controller
BCM5704CB
MS-9145
Dual K8 1U System
THOR AC97
53C1020C
ISL6522CB
DDR
ICS169
Sledgehammer DP
SIL3512
Storage Controller
NS/PC87366
Super I/O
8131
Northbridge / MCH
DDR REGISTERED
RC1117
ZIRCON UL95
