MSI MS-95A7 Rev 0b 100 Schematic
The MICRO-STAR AMS-95A7 motherboard, revision Ver:0A, was documented on 2004.06.14. The board number is MS-95A7. The schematic includes support for eight SATA connectors, labeled SATA 1 through SATA 8, each with associated serial IDE plus power connectors (JHD1 through JHD8). The design incorporates multiple voltage rails including 3.3V, 5V, and 12V, with various filtering capacitors and current-limiting resistors. Green LED indicators are present for each SATA channel.
Q: What is the board number and revision of this MICRO-STAR motherboard?
A: The board number is MS-95A7, and the revision is Ver:0A.
Q: How many SATA connectors are supported on this motherboard?
A: The schematic supports eight SATA connectors, labeled SATA 1 through SATA 8.
Q: What voltage rails are present on this motherboard?
A: The schematic includes 3.3V, 5V, and 12V voltage rails.
This MICRO-STAR motherboard, model AMS-95A7, is documented under board number AMS-95A7 with revision 0A. The schematic was authored on Tuesday, November 16, 2004, and carries the document number MS-95A7. The design includes eight Serial ATA connectors with integrated power, labeled JHD1 through JHD8, each supporting standard SATA signal and power pinouts. The board provides 3.3V, 5V, and 12V power rails to the SATA connectors, with associated filtering capacitors and current-limiting resistors. Green LED indicators are present for each SATA port to show activity or power status.
A: The board number is AMS-95A7, and the revision is 0A.
A: The document number is MS-95A7.
Q: How many SATA connectors are documented in this schematic?
A: There are eight SATA connectors with integrated power, labeled JHD1 through JHD8.
| Brand | MICRO-STAR |
| Model | AMS-95A7 |
| Motherboard Manufacturer | MICRO-STAR |
| Board Number | MS-95A7 |
| Revision | Ver:0A |
| Date | 2004.06.14 |
| Document Number | AMS-95A7 |
| Model | AMS-95A7 |
| Board Number | AMS-95A7 |
| Revision | 0A |
| Date | Tuesday, November 16, 2004 |
| Document Number | MS-95A7 |
