MSI MS-91A3 Rev 0A 0B 100 Schematic
This MSI MS-91A3 Rev 0A motherboard, dated March 18, 2008, is a dual-socket workstation platform built around the Intel LGA-1366 Nehalem-EP architecture with the Intel TYLERSBURG 36D and ICH9/10R chipset. The board supports up to 12 DDR3 modules across 6 memory channels, powered by ISL6312CR and ISL6545 regulators. Dual CPU VCORE is managed by ISL6334CRZ controllers, while VTT power is handled by ISL6314CRZ. The system integrates an SMSC/SCH5617C LPC SIO for legacy I/O, an ADI 1984A HD Audio codec, and an Intel 82567LM Boazman PHY for LAN. IEEE 1394 connectivity is provided by a TI TSB43AB22 controller. Thermal monitoring is managed by ADT7490 and ADT7462 sensors. The BIOS is stored on a SPI Flash device. Power delivery includes multiple rails using ISL6622, ISL6612, APL1084, and NTMFS4841 components.
A: The board number is MS-91A3, revision 0A.
Q: What CPU platform and chipset does this motherboard use?
A: It uses the Intel LGA-1366 Nehalem-EP platform with the Intel TYLERSBURG 36D and ICH9/10R chipset.
A: The EC/KBC is an SMSC/SCH5617C LPC SIO.
Q: What audio codec and LAN controller are integrated?
A: The audio codec is an ADI 1984A HD CODEC, and the LAN controller is an Intel 82567LM Boazman PHY.
Q: What memory architecture does this board support?
A: It supports 12 DDR3 modules across 6 channels, with 2 CPUs each having 3 channels.
The MSI MS-91A3 Rev 0B is a dual Intel LGA-1366 Gainstown/Nehalem-EP workstation motherboard built on the Intel TYLERSBURG 36D and ICH10R chipset. It features 12 DDR3 DIMM slots across 6 memory channels, powered by ISL6312CR and ISL6545 regulators. CPU VCORE is managed by dual ISL6334CRZ controllers, while CPU VTT uses ISL6314CRZ. The board integrates an SMSC/SCH5617 LPC SIO, ADI 1984A HD audio codec, Intel 82567LM Boazman LAN PHY, and IEEE 1394 via a TI TSB43AB22 controller. System monitoring is handled by ADT7490 and ADT7462 sensors. The SPI flash BIOS is present for firmware storage. Power delivery includes ISL6622 and ISL6612 drivers with NTMFS4841 switches. Expansion includes PCI Express x16, x8, and x8(4) slots, plus a PCI slot.
A: The board number is MS-91A3, revision 0B.
A: It uses dual Intel LGA-1366 Gainstown/Nehalem-EP CPUs with the Intel TYLERSBURG 36D and ICH10R chipset.
A: The EC/KBC is an SMSC/SCH5617 LPC SIO.
The MSI MS-91A3 REV 100 is a dual Intel LGA-1366 Nehalem-EP workstation motherboard built on the Intel TYLERSBURG 36D and ICH10R chipset. It features 12 DDR3 DIMM slots across 6 memory channels, supporting two CPUs. Power delivery is handled by ISL6334CRZ for CPU VCORE, ISL6312CR for DDR3 power, and ISL6314CRZ for CPU VTT. The board includes an LPC SIO SMSC/SCH5617C, an ADI 1984A HD Audio Codec, an Intel 82567LM Boazman LAN PHY, and an IEEE 1394 TI/TSB43AB22 controller. The SPI Flash BIOS is used for system firmware. Additional components include a TPM Infineon SLB9635TT1.2-RH, HWM ADT7490 and ADT7462 thermal sensors, an ICS932CK410B+ clock generator, and a PCA9545 SMBus multiplexer. The board is an 8-layer BTX form factor measuring 394mm by 330mm.
| Brand | MSI |
| Motherboard Manufacturer | MICRO-STAR INT'L CO.,LTD |
| Board Number | MS-91A3 |
| Revision | 0A |
| Date | Tuesday, March 18, 2008 |
| CPU Platform | Intel LGA-1366 Gainstown / Nehalem-EP |
| PCH / Southbridge | Intel TYLERSBURG 36D / ICH9/10R |
| GPU Type | External Graphics Card |
| EC / KBC | SMSC/SCH5617C |
| Audio Codec | ADI 1984A HD CODEC |
| BIOS / SPI Flash | SPI Flash BIOS |
| Charging IC | ISL6334CRZ |
| Power IC(s) | ISL6312CR, ISL6314CRZ, ISL6545, ISL6545CBZ, ISL6622, ISL6612, APL1084, NTMFS4841 |
| RAM Architecture | 12 DDR3 (2 CPU / 6 Channel) |
| RAM Quantity / Slots | 12 DIMM |
| LAN IC | [URL="https://dr-bios.com/components/lan-ic/82567lm-boazman-phy/"]INTEL 82567LM Boazman PHY[/URL] |
| Card Reader IC | tsb43ab22/"][URL="https://dr-bios.com/components/card-reader-ic/ieee1394-ti/"]IEEE 1394 TI Chip[/URL] TSB43AB22[/URL] |
| WiFi / WLAN IC | INTEL 82567LM Boazman |
| Thermal Sensor | ADT7490, ADT7462 |
| USB Hub IC | USB 2.0 (Rear x4, Front x4) |
| Brand | MSI |
| Model | MS-91A3 |
| Revision | 0B |
| Date | Friday, August 15, 2008 |
| PCH / Southbridge | Intel TYLERSBURG 36D / ICH10R |
| EC / KBC | SMSC/SCH5617 |
| Charging IC | ISL6334 |
| Power IC(s) | ISL6334CRZ, ISL6312CR, ISL6314CRZ, ISL6545, ISL6545CBZ, ISL6622, ISL6612, NTMFS4841, APL1084 |
| WiFi / WLAN IC | INTEL 82567LM Boazman PHY |
| Card Reader IC | [URL="https://dr-bios.com/components/card-reader-ic/ieee1394-ti/"]IEEE 1394 TI Chip[/URL] / TSB43AB22 |
| USB Hub IC | USB 2.0 (Rear x4 , Front x4) |
| HDMI Level Shifter | Not explicitly present in source |
| Brand | MSI |
| Model | MS-91A3 |
| Revision | REV 100 |
| Date | Thursday, December 04, 2008 |
| Graphics Architecture | PCI Express X16 |
| EC / KBC | LPC SIO [URL="https://dr-bios.com/components/ec-kbc/smsc-sch5617c/"]SMSC/SCH5617C[/URL] |
| Charger Architecture | CPU0 VCORE (95A) / CPU1 VCORE (95A) |
| Power IC(s) | ISL6334CRZ, ISL6312CR, ISL6314CRZ, ISL6545, ISL6622, ISL6612, ISL6545CBZ, APL1084, NTMFS4841 |
| RAM Quantity / Slots | 12 DIMMs (2 CPU / 6 Channel) |
| Card Reader IC | IEEE 1394 TI/TSB43AB22 |
| HDMI Level Shifter | NEC-TB3 |
| Thermal Sensor | adt7490-7462/"]HWM ADT7490 & 7462[/URL] |
| TPM | TPM Infineon SLB9635TT1.2-RH |
| Clock Generator | ICS932CK410B+ |
| SMBus Multiplexer | PCA9545 |
| Digital Potentiometer | ISL90728/90727 |
| Form Factor | 8 Layer BTX Form Factor (W 394mm X L 330mm) |
MS-91A3
LGA-1366 Gainstown
Nehalem
ICH9
SMSC/SCH5617C
1984A HD CODEC
ISL6334CRZ
APL1084
ISL6312CR
ISL6314CRZ
ISL6545
ISL6545CBZ
ISL6612
ISL6622
NTMFS4841
82567LM BOAZMAN
IEEE1394 TI CHIP TSB43AB22
ADT7462
ADT7490
ICH10R
SMSC/SCH5617
ISL6334
ISL6334CRZ
82567LM Boazman PHY
IEEE1394 TI CHIP
TSB43AB22
PCI Express x16
IEEE1394 TI
NEC-TB3
HWM ADT7490 & 7462
TPM INFINEON SLB9635TT1.2-RH
ICS932CK410B
MS-91A3
LGA-1366 Gainstown
Nehalem
ICH9
SMSC/SCH5617C
1984A HD CODEC
ISL6334CRZ
APL1084
ISL6312CR
ISL6314CRZ
ISL6545
ISL6545CBZ
ISL6612
ISL6622
NTMFS4841
82567LM BOAZMAN
ADT7462
ADT7490
ICH10R
SMSC/SCH5617
ISL6334
ISL6334CRZ
82567LM Boazman PHY
IEEE1394 TI CHIP
TSB43AB22
PCI Express x16
IEEE1394 TI
NEC-TB3
HWM ADT7490 & 7462
ICS932CK410B
