Schematic MSI MS-95A9 Rev 0A 100 Schematic
BrandMSI
ModelMS-95A9
Board NumberMS-95A9
Revision0A
Date2004/05/04
Document Number0AMS-95A9
PCB Numberms-95a9-0a/"]MS-95A9-0A[/URL]
Platform Alias2U 5V PCI Riser Card
PCI Bus ArchitecturePCI 64/33 5V / PCI-X / 3.3V/33MHz PCI Bus / 5V/33MHz PCI Bus
PCI SlotsPCI 5V Slot 1, PCI 5V Slot 2, PCI 5V Slot 3
Clock GeneratorICW-W16
Level Shifter5V / 3.3V Level Shift
PCB Layer Count4
PCB Copper WeightL1: H oz Foil, L2: H oz Foil, L3: 1 oz Foil, L4: 1 oz Foil
PCB Core Thickness47 Core (1/1)
PCB Prepreg ThicknessL1-L2: 3.5 mil, L2-L3: 3.5 mil
PCB ImpedanceSingle: 5mil = 50ohm
The MSI MS-95A9 Revision 0A, dated 2004/05/04, is a 2U 5V PCI Riser Card designed for PCI 64/33 5V and PCI-X bus architectures. The board is identified by document number 0AMS-95A9 and PCB number MS-95A9-0A. It features three PCI slots operating on both 5V/33MHz and 3.3V/33MHz PCI buses, with a dedicated 5V/3.3V level shifter for voltage translation. The clock generation is handled by an ICW-W16 clock generator. The PCB is a 4-layer design with a 47 Core (1/1) structure, using H oz foil on layers L1 and L2, and 1 oz foil on layers L3 and L4. The prepreg thickness between L1-L2 and L2-L3 is 3.5 mil, with a controlled single-ended impedance of 50 ohms at 5 mil trace width.
Q: What is the board number and revision of this riser card?
A: The board number is MS-95A9, with Revision 0A.
Q: What PCI bus architectures does this riser card support?
A: This riser card supports PCI 64/33 5V, PCI-X, 3.3V/33MHz PCI Bus, and 5V/33MHz PCI Bus architectures.
Q: What clock generator IC is used on this board?
A: The clock generator IC is an ICW-W16.
Q: What is the PCB stack-up and impedance control specification?
A: The PCB is a 4-layer board with a 47 Core (1/1), H oz foil on L1/L2, 1 oz foil on L3/L4, 3.5 mil prepreg between L1-L2 and L2-L3, and a single-ended impedance of 50 ohms at 5 mil trace width.
BrandMSI
ModelMS-95A9
Board NumberMS-95A9
Revision100
Date2004/07/08
Document Number100MS-95A9
Board Type2U 5V PCI Riser Card
PCI Bus ArchitecturePCI-X 64/33 5V
PCI Slots3
Clock Generator ReferenceU1
The MSI MS-95A9 is a 2U 5V PCI Riser Card designed for PCI-X 64/33 operation. The board revision is 100, dated 2004/07/08, with a document number of 100MS-95A9. It features three PCI-X 64/33 5V slots and utilizes an ICW-W16 clock generator at reference U1. The board supports both 5V/33MHz and 3.3V/33MHz PCI bus segments, with level shifting between 5V and 3.3V domains. The PCB stack-up specifies 1 oz foil on L3 and L4, with 0.5 oz foil on L1 and L2, and a 47 core thickness. The board includes a PCI-X Gold Finger connector and supports PCI clock distribution across three slots.
A: The board number is MS-95A9, revision 100, dated 2004/07/08.
Q: How many PCI-X slots does this riser card support?
A: This riser card supports three PCI-X 64/33 5V slots.
A: The clock generator is an ICW-W16 at reference U1.
  • MSI MS-95A9 Rev 0A Schematic.pdf
  • MSI MS-95A9 Rev 100 Schematic.pdf
