lenovo ideapad g505 compal la-9912p schematic 1
This Compal LA-9912P REV: 1.0 schematic, dated 2013-04-01, documents the VAWGA/B motherboard built on the AMD Kabini platform. The platform integrates an AMD FT3 APU with Jaguar Core and an integrated Yangtze FCH. Graphics are handled by an ATI Sun GPU. The system memory architecture is single-channel DDRIII, utilizing two 204-pin DDRIII SO-DIMM slots supporting 1.5V 1600MHz memory. The embedded controller is an ENE KBC9012. Audio is managed by a Conexant CX20757 codec. The BIOS is a 4M SPI flash device. Networking is provided by an Atheros AR8162/8172 LAN controller.
Q: What is the board number and revision for this Compal VAWGA/B schematic?
A: The board number is LA-9912P, revision 1.0.
A: The embedded controller is an ENE KBC9012.
Q: What is the BIOS flash size for this motherboard?
A: The BIOS is a 4M SPI flash device.
Q: What is the memory architecture and configuration?
A: The memory architecture is single-channel DDRIII, using two 204-pin DDRIII SO-DIMM slots at 1.5V 1600MHz.
| Model | VAWGA/B |
| Board Number | LA-9912P |
| Date | 2013-04-01 |
| CPU Platform | AMD Kabini |
| CPU Model | AMD FT3 APU BGA 769-balls Jaguar Core |
| PCH / Southbridge | Integrated Yangtze FCH |
| GPU Type | ATI Sun |
| Graphics Architecture | ATI SunVAWGA/B |
| EC / KBC | ENE KBC9012 |
| Audio Codec | Conexant CX20757 |
| BIOS / SPI Flash | BIOS (4M) |
| LAN IC | Atheros AR8162/8172 |
| RAM Architecture | Single Channel |
| RAM Quantity / Slots | 204pin DDRIII-SO-DIMM X2 |
