Schematic lenovo g505 la-9912p rev 1.0 schematic
BrandCompal
ModelVAWGA/B
Board NumberLA-9912P
Revision1.0
Date2013-04-01
CPU PlatformAMD Kabini
CPU ModelAMD FT3 APU BGA 769-balls Jaguar Core
PCH / SouthbridgeIntegrated Yangtze FCH
GPU TypeATI Sun
Graphics ArchitectureVAWGA/B
EC / KBCENE KBC9012
Audio CodecConexant CX20757
BIOS / SPI FlashBIOS (4M)
RAM TypeDDRIII
RAM ArchitectureSingle Channel
RAM Quantity / Slots204pin DDRIII-SO-DIMM X2
LAN ICAtheros AR8162/8172
WiFi / WLAN ICMINI Card (WLAN/BT)
Thermal SensorThermal Sensor
This Compal LA-9912P REV: 1.0 schematic documents the VAWGA/B motherboard designed for the AMD Kabini platform. The board is built around an AMD FT3 APU with Jaguar Core and integrated Yangtze FCH, paired with ATI Sun graphics. System memory is provided by two 204-pin DDRIII SO-DIMM slots operating in single-channel configuration at up to 1600MHz. The embedded controller is an ENE KBC9012, and the audio subsystem is handled by a Conexant CX20757 codec. Wired networking is supported by an Atheros AR8162/8172 LAN controller, while wireless connectivity is provided via a Mini Card supporting WLAN and Bluetooth. The BIOS is stored on a 4MB SPI flash device. The platform also integrates a thermal sensor for system monitoring.
A: The board number is LA-9912P, revision 1.0.
A: The embedded controller is an ENE KBC9012.
Q: What is the memory configuration for this platform?
A: The board supports single-channel DDR3 memory via two 204-pin SO-DIMM slots.
A: The wired LAN controller is an Atheros AR8162/8172.
  • Lenovo_G505=LA-9912P_Rev_1.0_DR-BIOS.COM.zip
