inventec mn10r bl10r ws build 6050a2377201-mb rev x03-10 2010.09.08
This Inventec EVEREST-MB-X01-20091119 motherboard, board number 6050A2351301 revision X01, is built around the Sandy-Bridge CPU platform (Socket-rPGA989) paired with the Cougar-Point PCH. The system utilizes DDR3 SODIMM memory across two slots, DDR3 DIMM1 and DDR3 DIMM3, interfacing via the DDR3 Interface. The embedded controller is a WINB_NPCE795LA0DX, and the audio subsystem is managed by a CONEX_CX20671 codec. BIOS storage is provided by an 8MB SPI Flash IC. Networking is handled by an ATHEROS_AR8151B Gigabit LAN controller and an ATHEROS_AR8152B 10/100 WLAN module. The charging circuit is built around a TI_BQ24725RGRR_QFN_20 charger IC, supported by multiple power ICs including TPS51218, TPS51125, MAX17039, G2997, AM4825, and PC6014. Peripheral support includes a REA_RTS5138 card reader controller and a GMT 708T1U USB hub IC.
A: The embedded controller is a WINB_NPCE795LA0DX.
A: The motherboard uses an 8MB SPI Flash IC for BIOS storage.
Q: What charging IC is used?
A: The charging circuit is controlled by a TI_BQ24725RGRR_QFN_20 IC.
Q: What is the CPU platform and PCH combination?
A: The platform is Sandy-Bridge (Socket-rPGA989) with a Cougar-Point PCH.
| Brand | Inventec |
| Project Code | EVEREST-MB-X01-20091119 |
| Board Number | 6050A2351301 |
| Revision | X01 |
| Date | 2010.09.08 |
| Document Number | SY1310A23513-0-MTR |
| CPU Platform | Sandy-Bridge (Socket-rPGA989) |
| PCH / Southbridge | Cougar-Point |
| EC / KBC | WINB_NPCE795LA0DX |
| Audio Codec | CONEX_CX20671 |
| BIOS / SPI Flash | SPI Flash 8MB |
| LAN IC | ATHEROS_AR8151B (Giga) |
| WiFi / WLAN IC | ATHEROS_AR8152B (10/100) |
| Charging IC | TI_BQ24725RGRR_QFN_20 |
| Power IC(s) | TPS51218, TPS51125, MAX17039, G2997, AM4825, PC6014 |
| RAM Type | DDR III _SODIMM |
| RAM Architecture | DDR3 Interface |
| RAM Quantity / Slots | DDR3 DIMM1, DDR3 DIMM3 |
| Card Reader IC | REA_RTS5138 |
| USB Hub IC | GMT 708T1U |
6050A2351301
Sandy-bridge SOCKET-RPGA989
NPCE795LA0DX
CONEX_CX20671
AR8151B
AR8152B
BQ24725RGRR_QFN_20
AM4825
G2997
MAX17039
PC6014
TPS51125
TPS51218
REA_RTS5138
GMT 708T1U
6050A2351301
NPCE795LA0DX
CONEX_CX20671
AR8151B
AR8152B
BQ24725RGRR_QFN_20
AM4825
G2997
MAX17039
PC6014
TPS51125
TPS51218
REA_RTS5138
GMT 708T1U
