hp pavilion dv4 inventec kitty14l uma-6050a2424501-mv build schematic
hp pavilion dv4=1=inventec kitty14l uma-6050a2424501-mv build.pdf
The Inventec Kitty UMA motherboard, board number 6050A2424501 revision A02, is built on the Huron River Platform supporting a Sandy Bridge CPU in an rPGA989 socket with a Cougar Point PCH. The system uses integrated UMA graphics and features two DDR3 SO-DIMM slots for memory expansion. The embedded controller is an ITE IT8572E, and the audio codec is an IDT 92HD80. A 4MB SPI ROM is used for BIOS storage. The charging circuit is managed by a TI BQ24726 IC. Networking is provided by an Atheros AR8151_BL1A LAN controller and a combined WLAN + Bluetooth module. The system includes a JMB709 card reader controller and a TI TMP431A thermal sensor. The document number is 1310A24245-0-MTR.
A: The board number is 6050A2424501, revision A02.
Q: What CPU platform and socket does this motherboard use?
A: It uses the Huron River Platform with a Sandy Bridge CPU in an rPGA989 socket.
A: The EC/KBC is an ITE IT8572E.
A: The BIOS is a 4MB SPI ROM.
Q: What charging IC is used?
A: The charging IC is a TI BQ24726.
| Brand | Inventec |
| Model | Kitty UMA |
| Project Code | Kitty |
| Board Number | 6050A2424501 |
| Revision | A02 |
| Date | 2010-12-01 |
| CPU Platform | Huron River Platform |
| CPU Model | Sandy Bridge |
| CPU Socket | Socket-rPGA989 |
| PCH / Southbridge | Cougar Point |
| GPU Type | UMA |
| EC / KBC | ITE IT8572E |
| Audio Codec | IDT 92HD80 |
| BIOS / SPI Flash | 4MB BIOS |
| Charging IC | TI BQ24726 |
| Card Reader IC | JMB709 |
| LAN IC | AR8151_BL1A |
| WiFi / WLAN IC | WLAN + BT |
| Thermal Sensor | TI TMP431A |
| Document Number | 1310A24245-0-MTR |
