hp pavilion dv4 cq40 compal la-4112p_ amd_rev1.0 schematic
hp pavilion dv4 cq40=1=compal la-4112p_ amd_rev1.0.pdf
The Compal LA-4112 schematic, revision 1.0 dated 2008-05-14, documents a motherboard built around the Mobile AMD S1G2 CPU platform with ATI RS780/RX781 northbridge and ATI SB700 southbridge core logic. Graphics are handled by a discrete ATI M82-SCE GPU with dedicated VRAM. The system BIOS is stored on a 25LF080A SPI ROM. Embedded controller functions are managed by an ENE KB926 EC/KBC. Audio is provided by an IDT9271B7 codec, and networking by a Realtek 8102EL 10/100M LAN controller. Memory configuration supports dual-channel DDR2 SO-DIMMs across two slots. The thermal management subsystem uses an ADM1032ARMZ sensor. A JM385 5-in-1 card reader controller is integrated for SD/MMC/MS/MSPro/XS media support.
A: The BIOS is stored on a 25LF080A SPI ROM.
A: The embedded controller is an ENE KB926.
Q: What is the graphics configuration of this motherboard?
A: This motherboard uses a discrete ATI M82-SCE GPU.
A: The memory architecture is dual-channel DDR2, using two DDR2 SO-DIMM slots.
| Model | LA-4112 |
| Document Number | 401568F |
| Date | 2008-05-14 |
| CPU Platform | Mobile AMD S1G2 CPU |
| PCH / Southbridge | ATI SB700 |
| GPU Type | ATI M82-SCE |
| Graphics Architecture | Discrete ATI M82-SCE |
| EC / KBC | ENE KB926 |
| Audio Codec | IDT9271B7 |
| BIOS Flash Exact Model | 25LF080A |
| Charging IC | TPA6017A2 |
| RAM Type | DDR2 |
| RAM Quantity / Slots | DDR2-SO-DIMM X2 |
| Thermal Sensor | ADM1032ARMZ |
| Card Reader IC | JM385 |
| LAN IC | Realtek 8102EL |
| WiFi / WLAN IC | 802.11a/b/g/n |
