hp pavilion dv4 quanta la-4117p_rev0.3 schematic
hp pavilion dv4=1=quanta la-4117p_rev0.3.pdf
This Compal LA-4117P Rev 0.3 schematic, dated 2009-03-15, details a motherboard built around the Mobile AMD S1G3 CPU platform with ATI RS880M (NB) and ATI SB710 (SB) core logic. The system BIOS is stored on an MX25L1605AM2C-12G SPI ROM. Embedded controller functions are handled by an ENE KB926-C0 KBC. Audio is managed by an IDT9271B7 codec with a TPA6017A2 amplifier. Networking is provided by a Realtek 8102E 10/100M LAN controller. System memory consists of two DDR2 SO-DIMM slots supporting dual-channel DDR2 800MHz 1.8V. Thermal monitoring is performed by an ADM1032ARMZ sensor. The board also integrates a JMicron JMB385-LGEZ0A card reader controller and supports Mini-Card WLAN and WWAN modules.
A: The BIOS SPI flash is an MX25L1605AM2C-12G.
A: The embedded controller is an ENE KB926-C0.
Q: What is the memory configuration for this motherboard?
A: The board supports two DDR2 SO-DIMM slots in a dual-channel architecture, running at DDR2 800MHz 1.8V.
Q: What is the LAN controller on this motherboard?
A: The LAN controller is a Realtek 8102E supporting 10/100M Ethernet.
| Board Number | LA-4117P |
| Revision | 0.3 |
| Date | 2009-03-15 |
| CPU Platform | Mobile AMD S1G3 CPU |
| PCH / Southbridge | ATI SB710 |
| GPU Type | ATI RS880M |
| EC / KBC | ENE KB926-C0 |
| Audio Codec | IDT9271B7 |
| BIOS / SPI Flash | MX25L1605AM2C-12G |
| RAM Type | DDR2 800MHz 1.8V |
| RAM Quantity / Slots | DDR2-SO-DIMM X2 |
| Thermal Sensor | ADM1032ARMZ |
| Card Reader IC | JMicron JMB385-LGEZ0A |
| LAN IC | Realtek 8102E |
| WiFi / WLAN IC | Mini-Card WLAN |
| HDMI Level Shifter | HDMI |
