Schematic hp elitebook 8470p-8570p inventec calvin discrete mv-build revd schematic
hp elitebook 8470p-8570p inventec calvin_discrete_mv-build_revd schematic
calvin_discrete_mv-build_revd_2012.07.16.pdf
BrandInventec
ModelDIS-MB-1310A
Motherboard ManufacturerInventec Corporation
Project CodeCALVIN DIS
Board Number1310A24700-0-ALG
RevisionA3
Date23-APR-2012
CPU PlatformIvy Bridge
Charging ICTI_BQ24736RGRR_QFN_20P
Charger ArchitectureSMBUS
RAM TypeDDR3_SO-DIMM
RAM ArchitectureSO-DIMM
RAM Quantity / Slots2
LAN ICNIC
WiFi / WLAN ICWLAN
Card Reader ICCard Reader Ctrl
GPU TypedGPU
Graphics ArchitectureIvy Bridge / dGPU
This Inventec DIS-MB-1310A motherboard, project code CALVIN DIS, board number 1310A24700-0-ALG revision A3, is an Ivy Bridge platform designed for a laptop form factor. The system utilizes DDR3 SO-DIMM memory across two slots and supports a discrete GPU (dGPU) architecture. Power management is handled by a TI BQ24736RGRR charging IC operating over SMBUS. The board integrates a dedicated NIC for LAN connectivity, a WLAN module, and a separate card reader controller. The schematic, dated 23-APR-2012, was drawn by Inventec Corporation and includes detailed subsystem pages for Ivy Bridge CPU power, GPU VRAM, system power rails, and various I/O interfaces including USB, eSATA, DisplayPort, and docking connector support.
A: The charging IC is a TI BQ24736RGRR in a QFN-20 package, operating over SMBUS.
A: This motherboard supports DDR3 SO-DIMM memory modules across two slots.
Q: What CPU platform is this motherboard based on?
A: This motherboard is based on the Intel Ivy Bridge platform.
Q: Does this motherboard support a discrete GPU?
A: Yes, this motherboard supports a discrete GPU (dGPU) architecture.
  • HP EliteBook 8470p-8570p=1=Inventec CALVIN_DISCRETE_MV-BUILD_RevD.zip
