hp_elitebook_2560p inventec_styx_build_mv_6050a2400201_rev-ax2_15abr2011 schematic
hp_elitebook_2560p_inventec_styx_build_mv_6050a2400201_rev-ax2_15abr2011.pdf
This Inventec STYX motherboard, document number AX21310A2400201 revision A3, is built around the Sandy Bridge CPU platform with integrated graphics. The system uses DDR3 SODIMM memory across two slots and is powered by a complex power delivery network including ISL62883, TPS51218, TPS51125, TPS51124, TPS51117, APL5331A11, and APL5930 regulators. Charging is managed by a TI BQ24726 IC. The board features an IDT 92HD80 audio codec, an Intel 82577 Gigabit LAN controller, and a Media Card Controller for card reader functionality. The EC/KBC is identified as KBCT, and the BIOS is stored on an 8MB SPI flash. Thermal monitoring is handled by a GMT G781 sensor.
A: The BIOS is stored on an 8MB SPI flash.
A: The EC/KBC controller is identified as KBCT.
A: The charging IC is a TI BQ24726.
A: The motherboard uses DDR3 SODIMM memory across two slots.
| Brand | Inventec |
| Project Code | STYX |
| Board Number | CSA35821310A2400201AX2 |
| Revision | A3 |
| Date | 9-Nov-2010 |
| Document Number | AX21310A2400201 |
| CPU Platform | Sandy Bridge |
| PCH / Southbridge | PCH |
| EC / KBC | KBCT |
| Audio Codec | IDT 92HD80 |
| BIOS / SPI Flash | SPI 8MB |
| Charging IC | TI BQ24726 |
| Charger Architecture | BQ24726 |
| Power IC(s) | ISL62883, TPS51218, TPS51125, TPS51124, TPS51117, APL5331A11, APL5930 |
| RAM Architecture | SODIMM |
| LAN IC | Intel 82577 |
| WiFi / WLAN IC | WLAN |
| Card Reader IC | Media Card Controller |
| Thermal Sensor | GMT G781 |
| GPU Type | Sandy Bridge |
| Graphics Architecture | Sandy Bridge |
| dGPU Chip Number | Sandy Bridge |
Sandy Bridge
92HD80
BQ24726
APL5331A11
APL5930
ISL62883
TPS51117
TPS51124
TPS51125
TPS51218
82577
GMT G781
Sandy Bridge
Sandy Bridge
92HD80
BQ24726
APL5331A11
APL5930
ISL62883
TPS51117
TPS51124
TPS51125
TPS51218
82577
GMT G781
Sandy Bridge
