hp pavilion dv5 inventec st145a-uma schematic
hp pavilion dv5=1=inventec st145a-uma.pdf
The Inventec ST145a - DIS is an AMD platform motherboard built to the CSA3533 project code, revision DB Build 2009/07/23. The board is powered by an AMD CPU platform paired with an RS880M GPU in UMA graphics architecture and an SB820M southbridge. System memory consists of DDR3 across two SODIMM slots and one side-port. Power management is handled by a TI BQ24721C charger IC and a suite of power ICs including MAX17480, TPS51117, RT8015A, APL5610, TPS51125, MAX17000, APL5315, and RT8015AP. The embedded controller is an ITE 8502E-KX. Audio is provided by an IDT 92HD80B1 codec. Networking is handled by a Realtek GIGA RTL8111DL-VB-GR LAN IC. A card reader IC, AU6433 5 in 1, is present. Clock generation and thermal sensing are managed by the RTM880N and RTM880N-796 devices respectively.
A: The embedded controller is an ITE 8502E-KX.
A: The charging IC is a TI BQ24721C_QFN_32.
A: The audio codec is an IDT 92HD80B1.
Q: What LAN IC is present on this motherboard?
A: The LAN IC is a Realtek GIGA RTL8111DL-VB-GR.
| Brand | Inventec |
| Model | ST145a - DIS |
| Project Code | CSA3533 |
| Board Number | Model_No X01 |
| Revision | DB Build 2009/07/23 |
| Date | 23-Jul-2009 |
| CPU Platform | AMD |
| PCH / Southbridge | SB820M |
| GPU Type | RS880M |
| EC / KBC | ITE 8502E-KX |
| Audio Codec | IDT 92HD80B1 |
| Charging IC | TI BQ24721C_QFN_32 |
| Charger Architecture | BQ24721C |
| Power IC(s) | MAX17480, TPS51117, RT8015A, APL5610, TPS51125, MAX17000, APL5315, RT8015AP |
| RAM Architecture | SODIMM0, SODIMM1, Side-port |
| RAM Quantity / Slots | 2 SODIMM slots, 1 Side-port |
| LAN IC | Realtek GIGA RTL8111DL-VB-GR |
| Card Reader IC | AU6433 5 in 1 |
| Thermal Sensor | RTM880N-796 |
| CLK GEN | RTM880N |
CSA3533
MODEL_NO X01
AMD
SB820M
RS880M
UMA
8502E-KX
92HD80B1
BQ24721C_QFN_32
APL5315
APL5610
MAX17000
MAX17480
RT8015A
RT8015AP
TPS51117
TPS51125
AU6433 5 IN 1
RTM880N-796
CSA3533
MODEL_NO X01
AMD
SB820M
RS880M
UMA
8502E-KX
92HD80B1
BQ24721C_QFN_32
APL5315
APL5610
MAX17000
MAX17480
RT8015A
RT8015AP
TPS51117
TPS51125
AU6433 5 IN 1
RTM880N-796
