hp pavilion dv5 dv5-1200 dv5-1222er quanta qt8g_rev1a schematic
hp pavilion dv5 dv5-1200 dv5-1222er=1=quanta qt8g_rev1a.pdf
The Quanta QT8NB5/RD5 platform is built around the AMD Griffin S1G2 processor with an SB700 A12 northbridge and M86-ME Lion Sabie RX781 discrete GPU. The system uses an ENE KB3926 Cx embedded controller and IDT 92HP61B7 audio codec with TPA6017A2 amplifier. Memory configuration consists of two DDRII-SODIMM slots supporting DDRII 667/800 MHz. The charging circuit is managed by ISL6251A, while system power is handled by ISL6236IRZA-T, TPS51116REGR, MAX8717, Oz8118, and ISL6265A. Networking is provided by a Realtek RTL8102E/8111C PCI-E LAN controller. The platform includes a RTS5158 card reader, LIS3LV02DL accelerometer, and ICS9LPRS476AKLF clock generator. The design supports dGPU to UMA conversion, with the discrete GPU being the M86-ME Lion Sabie RX781.
A: The ENE KB3926 Cx embedded controller is used.
A: Yes, the schematic indicates support for dGPU to UMA conversion, with the discrete GPU being the M86-ME Lion Sabie RX781.
A: The system charger is the ISL6251A.
A: The audio codec is IDT 92HP61B7 and the audio amplifier is TPA6017A2.
| Project Code | QT8NB5/RD5 |
| Date | Friday, August 29, 2008 |
| CPU Platform | AMD Griffin S1G2 Processor |
| Northbridge | SB700 A12 |
| Southbridge | M86-ME Lion Sabie RX781 |
| EC / KBC | ENE KB3926 Cx |
| Audio Codec | IDT 92HP61B7 |
| Audio Amplifier | TPA6017A2 |
| LAN IC | RTL8102E/8111C |
| Charging IC | ISL6251A |
| Power IC(s) | ISL6236IRZA-T, TPS51116REGR, MAX8717, Oz8118, ISL6265A |
| RAM Type | DDRII 667/800 MHz |
| RAM Architecture | DDRII-SODIMM |
| GPU Type | Discrete |
| dGPU Chip Number | M86-ME Lion Sabie RX781 |
| dGPU to UMA Conversion Support | Yes |
| Card Reader IC | RTS5158 |
| WiFi / WLAN IC | ICS9LPRS476AKLF |
| Thermal Sensor | LIS3LV02DL |
| Clock Generator | ICS9LPRS476AKLF |
QT8NB5
RD5
Griffin S1G2
A12
Northbridge / MCH
SB700
Northbridge / MCH
M86
RX781
KB3926 CX
92HP61B7
TPA6017A2
RTL8102E/8111C
ISL6251A
ISL6236IRZA-T
ISL6265A
MAX8717
OZ8118
TPS51116REGR
M86-ME LION SABIE RX781
RTS5158
ICS9LPRS476AKLF
LIS3LV02DL
ICS9LPRS476AKLF
QT8NB5
RD5
Griffin S1G2
A12
Northbridge / MCH
SB700
Northbridge / MCH
M86
RX781
KB3926 CX
92HP61B7
TPA6017A2
RTL8102E/8111C
ISL6251A
ISL6236IRZA-T
ISL6265A
MAX8717
OZ8118
TPS51116REGR
RTS5158
ICS9LPRS476AKLF
LIS3LV02DL
ICS9LPRS476AKLF
