hp pavilion dv5 quanta_qt8_rev1a schematic
hp pavilion dv5=1=quanta_qt8_rev1a.pdf
The Quanta QT8NB5/RD5 motherboard is built around the AMD Griffin S1G2 processor platform, paired with an RS780MN/S northbridge and SB700 A12 southbridge. Graphics are handled by the ATI M82-S Lion Sabie GPU, with support for dGPU to UMA conversion via depopulation of the discrete GPU and associated components. System memory consists of two DDRII 667/800 MHz SODIMM slots. The embedded controller is an ENE KB3926 Cx, and the audio codec is an IDT 92HD71B7. Power management is handled by an ISL6251A system charger, with multiple voltage regulators including the ISL6236IRZA-T, MAX8717, TPS51116REGR, Oz8118, and ISL6265A. Networking is provided by a Realtek RTL8102E/8111C LAN controller, and the system includes a JMicron JMD380 USB hub, RTS5158 card reader, TPA6017A2 audio amplifier, and LIS3LV02DL accelerometer thermal sensor.
A: The embedded controller is an ENE KB3926 Cx.
A: Yes, the schematic indicates support for dGPU to UMA conversion by depopulating the discrete ATI M82-S GPU and associated components, with flash media support for UMA-only configurations.
A: The system charger is an ISL6251A.
A: The audio codec is an IDT 92HD71B7.
| Brand | Quanta |
| Project Code | QT8NB5/RD5 |
| Date | Tuesday, February 19, 2008 |
| CPU Platform | AMD Griffin S1G2 |
| Northbridge | RS780MN/S |
| Southbridge | SB700 A12 |
| GPU Type | ATI M82-S |
| Graphics Architecture | Lion Sabie |
| EC / KBC | ENE KB3926 Cx |
| Audio Codec | IDT 92HD71B7 |
| Charging IC | ISL6251A |
| Power IC(s) | ISL6236IRZA-T, MAX8717, TPS51116REGR, Oz8118, ISL6265A |
| RAM Type | DDRII 667/800 MHz |
| RAM Architecture | SODIMM |
| LAN IC | RTL8102E/8111C |
| WiFi / WLAN IC | ICS9LPRS476AKLF |
| Card Reader IC | RTS5158 |
| USB Hub IC | JMICRON JMD380 |
| Audio Amplifier | TPA6017A2 |
| Thermal Sensor | LIS3LV02DL |
| dGPU to UMA Conversion Support | Yes |
QT8NB5
RD5
Griffin S1G2
RS780MN/S
Northbridge / MCH
A12
SB700
M82-S
Lion Sabie
KB3926 CX
92HD71B7
ISL6251A
ISL6236IRZA-T
ISL6265A
MAX8717
OZ8118
TPS51116REGR
RTL8102E/8111C
ICS9LPRS476AKLF
RTS5158
JMD380
TPA6017A2
LIS3LV02DL
QT8NB5
RD5
Griffin S1G2
RS780MN/S
Northbridge / MCH
A12
SB700
M82-S
Lion Sabie
KB3926 CX
92HD71B7
ISL6251A
ISL6236IRZA-T
ISL6265A
MAX8717
OZ8118
TPS51116REGR
RTL8102E/8111C
ICS9LPRS476AKLF
RTS5158
JMD380
TPA6017A2
LIS3LV02DL
