hp_dv5 quanta_qt6_uma_rev-2a schematic
hp_dv5=1=quanta_qt6_uma_rev-2a.pdf
The Quanta QT6NB5 project, revision 2A, dated October 29, 2007, is built around an Intel Penryn 478P (uPGA)/35W CPU platform with a Cantiga northbridge and ICH-9M southbridge. The embedded controller is a KB3926 B1 in a 92HP61B7X5NLGXA1X3X1X1 package. System memory consists of two DDRII SODIMM slots supporting DDRII 667/800 MHz. The audio subsystem features an ALPRS355B MLF64PIN codec and a TPA6017A2IDT amplifier. Wired networking is handled by a Realtek RTL8101E/8111C LAN IC. The charging IC is an ISL6251AHAZ-T, with system power managed by an ISL6237IRZ-T and CPU core power by an ISL6266A. Additional power regulation includes an RT8204 and a TPS51116REGR. A Realtek RTS51586 card reader, GMT G9931P1UP thermal sensor, and STMicroelectronics LIS3LV02DLSMBUS accelerometer are also present. The clock generator is a PS8101.
A: The EC/KBC is a KB3926 B1 in a 92HP61B7X5NLGXA1X3X1X1 package.
A: The system charger IC is an ISL6251AHAZ-T.
A: The audio codec is an ALPRS355B MLF64PIN, and the audio amplifier is a TPA6017A2IDT.
Q: What LAN IC is present?
A: The LAN IC is a Realtek RTL8101E/8111C.
A: The board supports two DDRII SODIMM slots with DDRII 667/800 MHz memory.
| Project Code | QT6NB5 |
| Revision | 2A |
| Date | Monday, October 29, 2007 |
| Northbridge | Cantiga |
| Southbridge | ICH-9M |
| EC / KBC | KB3926 B1 |
| EC/KBC Package | 92HP61B7X5NLGXA1X3X1X1 |
| Audio Codec | ALPRS355B MLF64PIN |
| Audio Amplifier | TPA6017A2IDT |
| LAN IC | RTL8101E/8111C |
| Charging IC | ISL6251AHAZ-T |
| Power IC(s) | ISL6237IRZ-T, ISL6266A, RT8204, TPS51116REGR |
| RAM Type | DDR II SMDDR_VTERM1.8V/1.8VSUS |
| RAM Architecture | DDRII 667/800 MHz |
| Card Reader IC | RTS51586 |
| Thermal Sensor | GMT G9931P1UP |
| Accelerometer | LIS3LV02DLSMBUS |
| Wireless LAN | Mini PCI-E Card |
| Clock Generator | PS8101 |
QT6NB5
Penryn
ICH-9M
KB3926 B1
ALPRS355B MLF64PIN
TPA6017A2IDT
RTL8101E/8111C
ISL6251AHAZ-T
ISL6237IRZ-T
ISL6266A
RT8204
TPS51116REGR
1 8VSUS
DDR2 SMDDR VTERM1 8V
RTS51586
GMT G9931P1UP
LIS3LV02DLSMBUS
Motion / Position Sensor
PS8101
QT6NB5
Penryn
ICH-9M
KB3926 B1
ALPRS355B MLF64PIN
TPA6017A2IDT
RTL8101E/8111C
ISL6251AHAZ-T
ISL6237IRZ-T
ISL6266A
RT8204
TPS51116REGR
1 8VSUS
RTS51586
GMT G9931P1UP
LIS3LV02DLSMBUS
PS8101
