hp compaq presario c500 ls-3342p rev 0.3 subcard audio board schematic
compal ls-3342p rev 0.3 subcard audio board.pdf
This Compal Electronics LS-3342P0.3 subcard audio board, dated November 13, 2006, is identified by PCB number LS3342P_PCB. The board integrates USB connectivity through an IP4220CZ6_SO6 USB hub IC and an AATI4610AIGV-T1_SOT23-5 power switch, supporting a USB port on the audio board. Audio functionality includes a microphone input, headphone output, and SPDIF output, with a dedicated audio board connector for HP Out and SPDIF. The design incorporates multiple N7002 SOT23 MOSFETs for signal switching and uses ferrite beads FBM-11-160808-601-T for power filtering. The board is a subcard assembly for the LS-3342 platform.
Q: What is the board number and revision of this audio subcard?
A: The board number is LS-3342P0.3, revision P0.3, with PCB number LS3342P_PCB.
Q: What USB hub IC is used on this audio board?
A: The USB hub IC is an IP4220CZ6 in a SO6 package.
Q: What USB power switch IC is used on this board?
A: The USB power switch IC is an AATI4610AIGV-T1 in a SOT23-5 package.
| Brand | Compal Electronics, Inc. |
| Model | LS-3342P0.3 |
| Board Number | LS-3342P0.3 |
| Revision | P0.3 |
| Date | Monday, November 13, 2006 |
| Document Number | LS-3342P0.3 |
| PCB Number | LS3342P_PCB |
