hp compaq presario c500 compal la-3341p_rev0.1 schematic
hp compaq presario c500=1=compal la-3341p_rev0.1.pdf
This Compal LA-3341P revision 0.1 motherboard schematic, dated 2006-05-19, documents a Mobile Yonah uFCBGA-479/uFCPGA-478 CPU platform with FSB 533/667MHz, paired with an Intel Calistoga GMCH graphics and Intel ICH7-M southbridge. The board features an ENE KB910/L embedded controller, an ALC audio codec, and a RealTek 8100CL LAN IC. Memory architecture consists of dual-channel DDR2-SO-DIMM X2 supporting DDR2-400/533/667. The clock generator is an ICS 954306, and thermal monitoring is handled by an ADM1032 sensor. The schematic includes BOM options for GM/PM/GML GPU variants and notes for ICH7 part number variations.
A: The ENE KB910/L embedded controller is used.
A: The RealTek 8100CL LAN IC is used.
Q: What memory configuration does this motherboard support?
A: This motherboard supports dual-channel DDR2-SO-DIMM X2 with DDR2-400/533/667 memory.
Q: What clock generator is used on this motherboard?
A: The ICS 954306 clock generator is used.
| Board Number | LA-3341P |
| Revision | 0.1 |
| Date | 2006-05-19 |
| CPU Platform | Mobile Yonah uFCBGA-479/uFCPGA-478 CPU FSB 533/667MHz |
| PCH / Southbridge | Intel ICH7-M |
| GPU Type | Intel Calistoga GMCH |
| Graphics Architecture | Intel Calistoga GM/PM/GML |
| EC / KBC | ENE KB910/L |
| Audio Codec | ALC |
| BIOS / SPI Flash | BIOS |
| RAM Type | DDR2-SO-DIMM X2 |
| Thermal Sensor | ADM1032 |
| LAN IC | RealTek 8100CL |
| Clock Generator | ICS 954306 |
