Schematic hp compaq presario c500 ls-3341p rev 0.1 switch board schematic
compal ls-3341p rev 0.1 switch board.pdf
BrandCompal
ModelLS-3341P
Board NumberLS-3341P
Revision0.1
Date2006-06-13
Document NumberLS-3341P
PCB NumberLS3341P_PCB
This Compal LS-3341P (PR) 0.1 switch board schematic, dated 2006-06-13, is a proprietary Compal Electronics, Inc. engineering drawing. The document, identified by board number LS-3341P and PCB number LS3341P_PCB, details a subcard switch board featuring power, wireless, and audio control interfaces. The design includes a G913CF voltage regulator (U3) for converting +5VS to +3VS, and incorporates ESD protection diodes such as the SM05T1G (D11, D12). The board utilizes a 25-pin FFC1 connector and multiple BT002-01210 4-pin tactile switches (SW1-SW5) for user input functions including power button, wireless on/off, and volume control. LED indicators for Num Lock, Power Active, Mute, and Wireless status are driven by signals from the mainboard EC, with blue LEDs sourced from Vendor Audix.
Q: What is the board number and revision of this switch board?
A: The board number is LS-3341P, revision 0.1, dated 2006-06-13.
Q: What voltage regulator is used on this switch board?
A: The board uses a G913CF voltage regulator (U3) in a SOT23-5 package to convert +5VS to +3VS.
Q: What type of ESD protection diodes are used?
A: The board uses SM05T1G ESD protection diodes (D11, D12) in SOT23-3 packages.
  • HP Compaq Presario C500=1=LS-3341P Rev 0.1 Switch Board.zip
